Something inside sliding when tipping the camera 90 degree up-right
Posted 03/06/2012 - 11:44
I had always this noise on my K-x, .. and others have mentioned it in various forums. I think that must be related to the way K-x was designed and built, .. I mean some kind of "structural noise", then unavoidable I'm afraid
Sorry, no proposal how to test SR-system.
Regards,
Regards,
Posted 03/06/2012 - 11:59
This is no doubt operational noise from the SR system. The instruction manual tells us to expect it and that it is quite normal.
Posted 03/06/2012 - 12:06
Will (Pentaxophile), what are you mean by "edit- but not in live view"?
I made quick and dirty test with SR Off/On and here are results. Left is SR Off and right SR On:
Picture taken from the calender on the wall by hand held (without tripod), shutter speed 1/20s and aperture f5.6. Picture are cropped from full size image. According this test SR seems to work.
Best Regards
Jukka
flickr
"If your photographs aren't good enough, you're not close enough." - Robert Capa
Jukka
flickr
Posted 03/06/2012 - 12:13
Just a guess as SR might be correct but there could be a mechanism that tells the camera when it in landscape or portrait hence the 90 tip?
Pentax K-x, DAL f3.5-5.6 18-55mm,Pentax-A 50mm f2, DAL f4-5.6 50-200mm, FG360FGZ
Posted 03/06/2012 - 12:27
Thanks for reminding us - yes, there is an orientation sensor, but that's not big enough to clunk. The clunk is SR for sure.
Posted 03/06/2012 - 12:36
Whether SR is on or off, the SR mechanism is in free motion, affected only by gravity, until the shutter button is half pressed. It's not until then that it is activated and it's electromagnetic system holds it in place.
So, you can expect it to make a noise, typically a dull thud, unless you are pressing the shutter release button.
Posted 03/06/2012 - 12:38
People keep saying 'it's the shake reduction'.The clunk is SR for sure.
In case it's not obvious, it's actually the whole sensor assembly.
Simple to see - take the lens off, lock the mirror up, and look in through the front while you move the camera about. I haven't done this since I did it with the K10D, but I don't imagine it's much different.
Posted 03/06/2012 - 12:45
It is the shake reduction technology. A good description of the system in the K100D is at the beginning of this article here -
http://www.steves-digicams.com/camera-reviews/pentax/k100d-slr/pentax-k100d-slr-...
Posted 03/06/2012 - 13:15
It is possible (on the K-5 at least) to see the effect of SR in Live View. The system damps high fequency vibration most obviously, so if you shake the camera quickly (and gently!), you can see the image float around slowly rather than shake. As expected this is more obvious with longer lenses.
Posted 03/06/2012 - 14:30
Whatever it is, its apparent as a dull clunk on the K10D and a tinkly sound on the K5. Doesn't effect the workings of either and in my case was there from new.
regards
Bernard
regards
Bernard
Posted 03/06/2012 - 17:30
As John said. IT IS THE SR !
Posted 03/06/2012 - 18:02
Surely that's just the standard sound of the orientation sensor?
Äänekoski,
Finland
Any proposal how to test SR-system?
There has been some discussions before link
I'm interested the sound because I fell with the bike and the camera (K-x) was in camera bag in the bike basket. K-x seems to work right and picture's quality seems to be OK and K-x has no external signs of shocks.
Jukka
flickr
