SMC-M 20mm f4 - scratched front element
Pentaxophile
Posted 15/07/2011 - 16:37 Link
I have picked up one of these lenses, knowing that the front element had some light scratching. I've taken a few test shots to see if there is any impact on image quality. There doesn't seem to be, to me at least. I tried shooting with the sun behind me (with the light) and towards the sun (against the light) and have been looking for haziness around high contrast edges etc.
Any thoughts on these shots? What sort of shooting conditions should I be wary of, or is a bit of scratching nothing to worry about?
Shooting with the light: http://www.flickr.com/photos/28055843@N04/5940396010/sizes/l/in/photostream/
Shooting into the light: http://www.flickr.com/photos/28055843@N04/5940397494/sizes/l/in/photostream/
Those shots are in-camera jpegs and you can click on the original size to have a good look. I must say that for the money I paid I'm quite pleased! It's not uber-sharp but the contrast is good and the colour seems great. And it's tiny!
The first shot but with a touch of curves:
Against the light, unedited:
Edited by Pentaxophile: 15/07/2011 - 16:55
Posted 15/07/2011 - 16:43 Link
It's a lovely lens, sharp and compact, but it does suffer from barrel distortion. Always use the dedicated lens hood if you have it.
Against the light shots will be the enemy of that scratch, but mostly you should be OK unless it's very bad. The traditional cure is to paint a scratch out with black paint. This stops it relecting light and causing flare.
How easy that would be is a different issue.
Pentaxophile
Posted 15/07/2011 - 16:59 Link
The scratches are widespread, but very light. I will try it with a hood, but I doubt the original Asahi Pentax skylight filter it came with will help very much. A pity the owner didn't make more use of the filter! The lens has clearly had a lot of use
Looking through my shots, blues seem especially vibrant. I like it.
Edited by Pentaxophile: 15/07/2011 - 17:12
Algernon
Posted 15/07/2011 - 18:40 Link
A lens hood should stop most of the problems. Be careful using
flash if it bounces back it will cause flare. It would be better
if the scratches were in a diamond pattern that would make the lens
work like a starburst filter.
Pentaxophile
Posted 15/07/2011 - 18:55 Link
Excellent, thanks, I'm not a big flash user (and I tend to bounce it off the ceiling if I do use it)... but I'll watch out for that.
Smeggypants
Posted 15/07/2011 - 20:30 Link
I can certainly see the barrel distortion in this one.
Pentaxophile
Posted 15/07/2011 - 20:45 Link
D'awww, that's mean!
LMAO though!
Stuey
Posted 15/07/2011 - 21:43 Link
Looks like a decent lens to me
My Flickr site link
