Shutter count in PhotoME
I often have this problem.
Roger.
'Manufacturer Notes' quite a way down - just after 'Shot Info Data'
I've tried a K-3 DNG, and a K-3 JPG. Neither seems to show that section.
Have you tried a K3 PEF file?
(I do not own a K3)
Roger.
I also tried exiftool and that did not show the K-3 shutter count either.
I needed to check the K-3 shutter count so in the end I used a tool on the other Pentax forum here which worked fine although only works for jpegs from the camera.
Glyn
I had exactly the same problem. Getting the shutter count using PhotoMe worked fine for my K-7 & K-5 but does not work for my K-3.
I needed to check the K-3 shutter count so in the end I used a tool on the other Pentax forum here which worked fine.
I'd noticed that link - works for me too, but I'd rather have something local that I can run.
To get it to work, I had to also:
- download the standard ExifTool,
- extract the contained exiftool(-k).exe into the folder containing the extracted GUI version
- rename exiftool(-k).exe to exiftool.exe
Then the GUI works a treat.
Glyn
South West London
Can someone please tell me which tag/section it's in, cos I'm damned if I can see it...
