Settings on K7 for Sigma 600 mirror?
coker
Posted 15/03/2010 - 19:15 Link
Having progressed from MX to Optio S5i, decided (thanks to a windfall) to further progress to the K7(!)
Despite wading through the K7 "bible", I can't use the Sigma.
Please: anyone advise the settings necessary to progress?
Coker
Anvh
Posted 15/03/2010 - 19:26 Link
You need to allow use of the aperture ring, it's #37, it's on page/tab 6 of the custom menu.
Stefan
K10D, K5
AF-540FGZ
coker
Posted 15/03/2010 - 22:39 Link
Thanks, ANVH.
HOWEVER......
I get record, playback, set-up..... then record again, etc, eyc.
How do I get into the Custom setting menu???
Coker.
Anvh
Posted 15/03/2010 - 22:52 Link
From what I understand you should be able to select it just like record, playback, set-up, custom menu will be the fourth one.
The problem most likely is that you've the camera on green mode simply set it to another mode and you can select it.
In case you didn't know, because the lens does not have an auto-aperture you can only use Av or Manual mode.
Stefan
K10D, K5
AF-540FGZ
mayday
Move dial away from Green mode, ie P and then press menu. Keep pressing the cursor button to the LH until you see the Orange C, KEEP GOING to Tab 6 and option 36 (Using Aperture Ring)
Hope that helps
Retired at last - now all that time for photography - you would think: wink:
coker
Posted 15/03/2010 - 23:07 - Helpful Comment Link
Many thanks.
Watch this space!
Coker.
