setting sharpness in K7
almierau
Posted 05/09/2012 - 00:01 Link
I recently found out by viewing the exif data that the sharpness showed "soft". I cannot find out in the menu's where one sets, "soft" "normal" "hard". I therefore did a "reset" and now the exif shows the image has "hard". Where in the world does not navigate in the menu to change this setting without having to go the reset mode.
Posted 05/09/2012 - 00:15 Link
If you look in the Index of your Operating Manual you will find Sharpness. I can't be more specific as I use the K-5 and it may or may not be exactly the same as your K-7.
almierau
Posted 05/09/2012 - 01:06 Link
They were not quite specific about this, however I did find the solution. I have to thit the controller at the 3 o'clock position. This brings up eight different modes and on each mode one can offset the defaults, including sharpness from soft to hard. Somewhere along the line someone (me) must have set the system to an item that takes soft focusing.
One issue I have not been able to resolve however with this k7, is how to get the skies more blue, as compared to my fuji or canon cameras, and none of those are SLR's. However I shoot landscapes in RAW, for the most part, so one can always adjust later. Two of my friends just bought the K5 and are very happy with their purchases.
Thanks for the prompt reply.
snappychappy
Posted 05/09/2012 - 07:21 Link
I think the majority of use "never read the manual" we are too impatient to get out there shooting.
Posted 05/09/2012 - 08:19 Link
Pentax Colour tends to be quite realistic and some other marques over-exaggerate, so you may need to set your camera to Vivid to get what you want. However, this only applies to JPEG capture, so it might be an idea to give JPEG a try with all picture styles to see what suits.
bettyswolloks
Posted 05/09/2012 - 09:33 Link
I use a K-7 most of the day, I can't find the sharpness settings, looked when set to jpg and still nowt. So sorry OP I'm no use ;O)
dinneenp
Posted 05/09/2012 - 09:56 Link
I keep a pdf copy of the K7 mnaual locally, from Page 205 and 206 of the pdf:
HI,
Cheers,
Pa
Edited by dinneenp: 05/09/2012 - 09:57
bettyswolloks
Posted 05/09/2012 - 10:22 Link
Aahhh a place I never visit!
McGregNi
Posted 05/09/2012 - 16:25 Link
Come on then all, lets pull out those little booklets and start studying.
I actually do rather enjoy reading instructions, but I accept I will forever remain in a minority. I bought a very good guide book to the K7, the Magic Lantern Guide by Peter Burian, and I thoroughly recommend it - it puts the settings into a practical context, and gives working examples of why you might choose one particular option over another (such as what might be the effect of linking AE-L to the active focus point, or not, - something I had not spent much time pondering previously).
But it helped brilliantly (to me, completely new to DSLRs and Pentax)to quickly get my camera set up for manual lenses, and many other usability features.
beakynet
Posted 07/09/2012 - 11:05 Link
I have found a circular polarser very effective is raising the level of blue in skys.
Flash: Metz 58, Metz 48
SteveEveritt
Posted 07/09/2012 - 17:49 Link
When using a DSLR there are only two rules.
1. get a manual lens and learn how to use it by...
2. RTFM
over and over and over trying out everything it offers and settling on what you like best.
beakynet
Posted 07/09/2012 - 18:03 Link
2. RTFM
When I had my K10, I skipped most of the manual and read the Magic Lantern guide, made notes or had my camera in front of me. That way I ensured I understood all the settings and tried things out. It was invaliuable.
MrB
Posted 08/09/2012 - 09:09 Link
It is a pleasure to see a discussion about camera settings, without the typical put-down of disparaging comments such as, "Why are you bothering with those settings - are you not shooting Raw?". I am still learning about them, but I suspect there are many who have learnt to use the extensive in-camera settings, who are pleased with the Jpeg output from their Pentax cameras, and who have discovered that (if necessary) they still have plenty of leeway for adjustment in PP, to produce high quality photos when viewed at normal print/screen size (e.g. typically A3 or A4).
Philip
McGregNi
Posted 08/09/2012 - 19:14 Link
Yes, if you are shooting JPEGs only it does make sense to take command with these in camera settings. Our Pentax DSLRs, in addition to a wide range of preset 'Custom Image' modes, also have a great deal of individual tweaking sliders for finer control.
But, I look at it this way - the 'native' format for digital cameras is RAW (specific to each camera), so any output from the camera that we use to view, print etc is actually a 'conversion', and if we make any changes to exposure, WB, contrast, saturation etc, then we are 'editing' also.
This applies to outputting a 'conversion' or 'edit' directly from the camera or from a computer. The key differences I think come down to ease of use, efficiency and the degree of finer control we can exert. In my view, these aspects are all superior on a computer with various software deployed. Do I think you can get a higher quality image this way than on JPEG from the camera ? Yes, I believe in all situations the potential for this is there in RAW with computer editing.
Interestingly, I have recently taken a great interest in the Custom Images settings - not applied in camera, but using the Pentax Digital Camera Utility software. It has become my first 'conversion' step in my workflow. Why ? Because I think the quality of edits it applys is very high, and the fine control exceptional.
I think (for example) the white balance fine controls produce the best results that I have seen, and the Highlights Correction feature (as seen in Silkypix) is very sophisticated (you can control the degree of Saturation or hue that is pulled back into clipped highlights).
And you have additional controls for the available lens distortion and chromatic abberation corrections (auto and manual controls). Output to 16bit TIFF and you can carry on in another editor if needed.
