ExpoDisc on a Pentax DSLR
McGregNi
Posted 18/07/2012 - 22:41 Link
I have been less than entirely happy with the amount of fine tuning needed to get White Balance just right, since I've starting shooting on my new K7. I guess that its a software issue as well, but I've become more commited to the pursuit of achieving perfect WB in camera.
To this end I experimented with the Manuel WB option, and then took a look at this interesting product, the ExpoDisc. link
I would love to hear anyone elses experiences with this - especially on Pentax gear. From my trials with manual settings on the camera I can see the issues and why you might need an extra helping hand. The Pentax manual instructs you to shoot at a white surface to set the manual WB - I tried this on an overcast day with a pure white windowsill in front of me. The foliage outside was a rather cool unsaturated greeny tone.
But the white windowsill looked pure white to me. After setting the WB using this surface of white, I took the shot with the newly programmed setting - imagine my surprise to see a scene of very warm tones appear, more like a shade WB setting, or a warmup filter.
Then I realised, this is what these Expo guys have been saying - the camera is detecting all the cool light around, and compensating to try and achieve pure white, in this case by adding warmer tones. The result of my attempt at manual and acurate white balence was not accurate at all!
So this ExpoDisc with its 18% grey reproduction, removing any ambiant cast, looks very intriqing. Does anyone think this could be worth the £50 or so?
Posted 18/07/2012 - 23:37 Link
It depends whether or not you need to adjust WB at all. For very precise applications maybe. For example, in advertising a Cadbury's wrapper has a very precise colour and this needs to be the same, everywhere, all the time.
For more pictorial uses I generally just use Daylight. I turn off the camera fine tune so it is a fixed value and the colour is superb. One of the Pentax strengths is the fine colour reproduction.
If you use RAW then you should be able to also choose daylight setting or, if you want a warmer result choose Cloudy.
Mannesty
Posted 18/07/2012 - 23:45 Link
I have a couple of Expodiscs of different sizes. I made the mistake of buying a small one, only to replace it later with a bigger one and some step down rings for my smaller diameter lenses.
Using the Expodisc on very early Pentax DSLR's was a breeze. Manual WB was no more than a button press or two (can't remember exactly).
Nowadays it's not so easy to use, but does give very accurate results.
Perhaps a better/cheaper alternative would be a good quality 18% grey card, or even a grey card that has both black and white surfaces too. Then all you need do is shoot RAW and correct in PP.
Edited by Mannesty: 18/07/2012 - 23:45
SteveLedger
Posted 19/07/2012 - 07:13 Link
Never had any trouble with the K7. I use the custom/manual setting all the time when WB is important to me. I aim the camera at something white or light grey near me which is in the same light conditions as where I'm shooting (there's always something I can use.)
More recently I have been using a Mennon WB lens cover for the 250mm lens.
Takes just a few seconds and I'm set, works well.
Of course, if I'm shooting RAW I don't bother because I can set the WB in lightroom later, but I shoot raw very little only because what I shoot a lot doesn't warrant post processing to that degree.
To access the WB on a K7 is one single button press which if you are normally using the manual setting will come up on manual every time.
(Was 2 presses on the *istDS)
Algernon
Posted 19/07/2012 - 08:03 Link
ExpoDisc's are great. You have to remember to press the Green Button
and take an exposure reading first (it needs to be seeing grey not white).
Although not as good as the ExpoDisc the light grey WhiBal card is
a 2nd choice. They also have some good videos on their site explaining
why you should use light grey and not 18% grey.
http://www.whibalhost.com/_Tutorials/WhiBal/01/
A white card is a very poor choice, unless you meter it as grey,
because it burns out to easily when exposed as white. In fact
an overexposed yellow card will look white
Algernon
Posted 19/07/2012 - 09:45 Link
Once you have set the balance with the ExpoDisk still in
place it's easy to take a shot at each aperture to see
what apertures to use to get accurate meter readings.
This may be of interest to some. I used a couple of 'M'
lenses exposed via the Green Button at every aperture f/2.8 to f/22
I then read the RGB values off the jpegs.
f/5.6 to f/11 either gave the correct exposure or it would be correct
with a small amount of compensation. Outside of that the photo was too
dark. Open aperture readings are way out and also heavily vignetted.
Pentaxophile
Posted 19/07/2012 - 09:52 Link
Ah-ha! I had noticed that there was some 'creep' in the actual WB when using fixed WB settings - very annoying when the whole point of the fixed settings should be consistency! Would be grateful if you could confirm how this can be turned off, John.
McGregNi
Posted 19/07/2012 - 10:10 Link
My own experiment seemed to suggest that with the camera WB settings what you see is not necessarily what you get. I am thinking our human eyes are an amazing light interpretation tool - it was obvious that in the cool overcast shooting conditions (not uncommon here in England at present:cry what I saw as a pure white surface was seen by the camera as having plenty of blue tones which my eyes had apparently compensated for.
But the camera's compensation (this is when carrying out a custom white balance setting as described in the manual) was too much - I got a strong 'warm-up' filter effect, not what I wanted at all. I was trying to achieve the most realistic representation of the tones in the seen as my eyes saw it.
Interestingly, the effect I got from my custom setting was pretty much the same as another shot taken on Auto White Balance, so I guess in auto mode the camera is designed to find white tones and go from there, but thats not much good if there are radiating ambiant tones that are overiding the white object. This expo disc appears to provide the means to filter out these and give the camera the pure tone needed to accurately represent the scene.
My own issue with correcting WB in software is to do with the crossover between actual ambiant tone setting and just altering saturation levels of different parts of the 'colour wheel', which I sometimes feel is all that is actually happening.
Algernon
Posted 19/07/2012 - 10:59 Link
Daylight WB is only correct at Mid-Day
Pentax AWB is very accurate.
Edited by Algernon: 19/07/2012 - 10:59
Posted 19/07/2012 - 12:12 Link
First the WB fine tune. Custom menu C2 - WB adjustable range. Switch this off and the WB will be fixed.
Now why Daylight WB. Let's take an extreme example. Suppose we have a red sunset. If we use daylight it will be red. If we use AWB the one colour will make the camera want to compensate and dilute the effect.
I use daylight because I use the colour of ambient light and want to retain its qualities. Don't forget that when we used film, daylight film was a fixed WB too. If I want a warmer result (81A filter) then I set Cloudy. If I have very mixed lighting then I might use AWB. In tungsten light I might well use Tungsten setting, just as I would have bought a tungsten film.
Pentaxophile
Posted 19/07/2012 - 12:24 Link
Excellent. Thanks John.
I agree, AWB is usually really good. However sometimes I want to shoot preset WB for consistency between shots, and ease of batch-editing in Lightroom! (I've also noticed the WB creep around when I'm using the flash WB preset - that's not desirable!)
Really I should be doing a custom WB. Reality is, I'm too lazy.
Edited by Pentaxophile: 19/07/2012 - 12:26
Algernon
Posted 19/07/2012 - 12:55 Link
I normally use 4500K Custom for flash because it's usually
bouncing around of warm walls, curtains etc.
Indoors with the Eye-Fi card and a laptop I can just take a shot of a grey card
and check the RGB values are right for CB and exposure before
taking any more shots.
Be careful with AWB under trees, it interprets the green light
as fluorescent
Edited by Algernon: 19/07/2012 - 12:56
FAT8BIKER
Posted 19/07/2012 - 13:01 Link
I shoot RAW and for most shots choose shade for WB, i like the warmth it gives, maybe not natural but i like it and thats what counts.
Looks like the sun's finaly on the way.
Dave
Posted 19/07/2012 - 13:51 Link
Depending on the camera, Shade is another useful option. Different marques have different characteristics too. Fortunately Pentax is very good for colour.
McGregNi
Posted 19/07/2012 - 14:45 Link
Obviously it is not going to be practical all the time to take these custom readings, with or without ExpoDiscs or grey cards - its not lazy, just the reality of shooting in the real world. So its good practice then to try and choose the closest preset available, althought it sounds like we need to understand a bit about the processes the camera is applying when reading the temperature.
This custom menu C2 setting is clearly important - I understand that (as John was advocating) setting it to 'fixed' - that is no variation from the preset K value - will prevent any shifting of the range to compensate for strong tones (sunset etc).
Maybe this is the best way to use the camera, at least to gain consistency between shots. The problem we all have with these highly automated camera features is not knowing the extent of their effects and under what circumstances they are applied (like the under the trees example above). This is equivalant to the problem of using evaluative metering and not knowing what 'compensations' have already been factored in to the EV set by the camera.
