Serial Numbers
Posted 28/01/2010 - 19:46
Lens serial number is not recorded in Exif.
Glover & Howe don't ask for serial numbers, or any details at all, in advance for each sub £150 item, as they are included in your "misc items" total.
~Pete
Posted 28/01/2010 - 19:49
Ah! The little box at the bottom of the form asks for a list of equipment including serial number.
I'll fill in the form without it and see what happens.
Posted 28/01/2010 - 19:52
Yes, but with Glover & Howe, you don't have to list items that have a value of less than £150 each at all.
You just list £150+ items, then enter a total amount for "Misc items".
So you don't even have to mention your kit lens, just include the value in the Misc.
I can't speak for other insurers. Some may ask you to list everything, some nothing.
~Pete
Posted 28/01/2010 - 21:06
Do Glover & Howe offer discount for club members? I had very good experiences with them when I used ( and trashed ) C**** gear.
But I remember getting discount through the C**** club.
Posted 28/01/2010 - 21:45
https://www.pentaxuser.com/insurance
Posted 29/01/2010 - 12:04
Cheers. I must have mis read the form
Thought it was after all of my serial numbers.
As my camera is an *istDL, what sort of figure should I be looking to insure for? If anything happened, it is unlikely I'd replace with that as it is old. Should I be looking to cost for a K10 / K20.
Not really sure
Not really sure
Posted 29/01/2010 - 12:35
Not sure. If the policy is for replacement cost, then the most up to date model's price should be given i.e. K20D, otherwise I would speak to your agent. This is were knowing what the policy pays helps.
The Photomonk
The Photomonk
Posted 29/01/2010 - 12:37
From http://www.gloverhowe.com/media/Amateur%20Summary%2004%2007.pdf :
"Full replacement (New for Old) – your sum(s) insured is to represent the full replacement cost of your equipment. In the event of an item being out of production or discontinued, your sum insured must represent the replacement cost of the nearest equivalent item."
I'm not sure if that allows you to buy a second-hand replacement if you would prefer that to a new model, for example a K10D instead of a K-m.
Bear in mind that the DL was the lowest model in the range at the time, and the K10D, K20D and the K-m are officially discontinued. The current lowest model is the K-x.
Perhaps an email to G&H would clear it up. Sorry I'm not clear myself.
~Pete
Posted 29/01/2010 - 13:27
I did speak to them about this. I've got my K200D insured with them. If that broke, and I wanted to say buy a K7, I could get the cash amount I'd insured the K200D for, and add the extra myself.
Alternatively, I could have insured the K200D for the amount a K7 would cost, but then you're paying higher premiums....
k5, 50mm FA, 18-55mm Kit, 50-200mm DA, 15mm Fisheye Sigma, 10-17mm DA Fisheye, 18-55mm DA WR, DA* 60-250, DA* 16-50
Wirral
I remember being asked to detail serial numbers for lenses etc. No problem, but the serial number sticker has come off my kit lens. Is it recorded electronically in the background, ie, with the EXIF info?
Will it be a problem to get insurance with no serial number? I've got all of the others.
