Sensor Cleaning, a new solution?
Posted 11/02/2014 - 08:59
never had to clean the sensors on my K-5's
the Hi Freq shaking works a lot better than the LF system on the older models
Posted 11/02/2014 - 09:07
Pentax have been marketing similar for a while now, available from SRS and others. I bought one when a spot would not be removed by the high frequency shaking.
It may seem expensive, but it is an intelligent buy if vibration doesn't work and you need to clean a sensor. I would be very wary of letting anything else in contact with a sensor surface.
Posted 11/02/2014 - 09:18
Yikes, that looks massive! From his demo it looks good and easy. I bought a speckgrabber (which was the same era the Pentax version I think) a couple of years ago which looks like a mini version of that. It picked up dust nicely, but it did leave a residue that was visible in photos and about 4 times the size of the original spot. I ended up having to wet clean the sensor to get rid of the mark. Still in my drawer if anyone wants it for a fiver?
Posted 11/02/2014 - 09:22
I presume you don't make your living in sales?
Posted 11/02/2014 - 09:26
Mike-P wrote:
I have had one of those for nearly a year.
Does it work?
Posted 11/02/2014 - 09:49
Wet cleaning is still the best method when you need to clean it and your cam doesn't have ultrasonic sensor shaking.
Posted 11/02/2014 - 10:03
I've got the Pentax version mentioned above and, yes, it works. (Or worked - used mainly on *istDS rather than K5, haven't needed it for a while). No residue that I'm aware of.
Tony
Tony
Posted 11/02/2014 - 10:24
Same problem here I've never had to clean the sensor of my K5. The sensor shake at startup works great.
Posted 11/02/2014 - 14:00
It looks quite impressive but I suspect a rocket blower would have shifted most of the dust. I haven't had to clean a sensor since the *istDS. £49.99 for the Pentax one seems a bit steep
Posted 11/02/2014 - 14:32
Not quite sure how all that dab, dab, dab (and in the video he was pressing quite hard) is much easier than a wipe with a wet-clean swab.
Not to mention the cost.
After two years, my K-5 finally has a couple of dust spots that don't shift with the auto-clean, which I've had set to operate on start-up since I've had the camera.
I still have the swabs and fluid since I cleaned my K10D sensor. It's a really easy process, people shouldn't be scared of it.
Posted 11/02/2014 - 15:14
One thing I did see mentioned elsewhere, and I'm not sure if it's an issue for us, is to watch that you don't drag any lubricant/grease from off the sensor onto it when wiping. That seemed like a good point, but I'm not sure if there actually is anything too nasty off to the side or not anyway?
Posted 11/02/2014 - 17:05
Mike-P wrote:
Nope! It was worth a try... gotta raise cash to upgrade the old K5 somehow!
I presume you don't make your living in sales? It picked up dust nicely, but it did leave a residue that was visible in photos and about 4 times the size of the original spot. I ended up having to wet clean the sensor to get rid of the mark. Still in my drawer if anyone wants it for a fiver?
Storbritannia
