Sensor cleaning?
DanielH
Posted 21/03/2011 - 13:13 Link
Strange one,
I've got what looks like a dust spot on the sensor. It's not on the lens ive thoroughly cleaned it and tried it with another lens and i get the same spot in same position.I did a dust check "picture" but it shows completley clean!? Then sensor shake cleaning several times but its still the same.
Now what? mirror up cleaning with lenspen? Some advice would be appreciated many thanks
Dan.
greynolds999
Posted 21/03/2011 - 13:20 Link
Can you clarify. Is this spot visible on actual photographs or only when you look through the viewfinder.
If it's on the sensor you won't see it through the viewfinder - if you can see it through the viewfinder it will be on the mirror or the focussing screen.
Edited by greynolds999: 21/03/2011 - 13:21
Oggy
Posted 21/03/2011 - 13:36 Link
What camera is it Dan?
Gwyn
Posted 21/03/2011 - 15:06 Link
Whatever you do do not use a lens pen on your sensor .
Invest in an Arctic Butterfly or swabs for sensor cleaning.
Tyr
Posted 21/03/2011 - 15:47 Link
+1 for Arctic Butterfly in 4 years with a K10D only once have I done a wet clean thanks to mine.
Oggy
Posted 21/03/2011 - 15:58 Link
I am a butterfly enthusiast as well, but only for dry dust. It will simply smear grease.
Tyr
Posted 21/03/2011 - 16:10 Link
How do you get grease on the sensor?
greynolds999
Posted 21/03/2011 - 16:15 Link
Eating chips in Whitby!
(But pollen is the killer)
alfpics
Posted 21/03/2011 - 16:21 Link
Probably - I have had the same recently on the K7!
Andy
Andy
Gwyn
Posted 21/03/2011 - 16:25 Link
Andy
Hopefully not with a lens pen though .
Tyr
Posted 21/03/2011 - 16:26 Link
Blimey, they must serve you the oil they were fried in as well then
I accidentally got some saliva on my sensor because I was talking to someone while cleaning it. I shall not make that mistake again, damn 's' sound!
Smeggypants
Posted 21/03/2011 - 17:16 Link
Wet swabs here.
Intersetingly ( and probably tempting fate ) but I haven't had toclean my K-5s sensor at all despite changing lenses in all manner of dirty environments. K20D OTOH was always gettign crap on it the sensor
pianoman
Posted 21/03/2011 - 17:40 Link
I confess I send mine off to be cleaned works out the same as buying the swabs and Im not confident enough to attempt it.
Dont use the lenspen on the sensor though!!!! lens (its in the name )
All the best
DanielH
Posted 21/03/2011 - 18:17 Link
Well to clarify its definately on the sensor (I dont understand though how it DOESENT show up in the dust alert picture). It shows up in my pics. And there is also stubborn dust on the mirror! I'm going to try a hairdryer on cold to see if i can blow it out.....wish me luck
thanks for everyone's advice
pianoman
Posted 21/03/2011 - 18:26 Link
I do wish you luck careful you dont shake anymore dust onto the area
Will await the outcome
All the best
