Sensor cleaning - again!
Gwyn
Posted 22/05/2008 - 04:28 Link
Reading up on this subject as it is time for me to clean the sensor. Blowing is not enough - it is just to dirty atm.
So - anyone used eclipse (or similar) products. Could someone post a link to a good supplier???
I have never used Eclipse but if you have a K10D or later you must make sure you buy the right fluid, as the original one can damage the sensor.
Also I believe you are not allowed to fly with Eclipse fluid. I am a Acrtic Butterfly user myself. I am very happy with it and making good use of it here in the dusty SW USA.
Nimitz
Posted 22/05/2008 - 08:56 Link
Thanks Gwyn.
I have read a bit about it. Seems to be something called E2.....for the K10D.
I just have tof ind a decent supplier now. ANYONE??
My dustspots are pretty sticky. I can't blow them off. I tried several times.
Posted 22/05/2008 - 09:22 Link
Nimitz,
The list of suppliers is here: http://www.photosol.com/world_dealers.htm
In the UK you can get E2 from Camera Clean.
Though I haven't bought any yet.
mikew
Posted 22/05/2008 - 09:26 Link
Bring me up to speed - why aren't you using a brush of some form?
I've been trying to get a copperhill brush without paying high shipping costs.
ChrisA
Posted 22/05/2008 - 09:54 Link
How close to the sensor are you getting the nozzle of the blower?
I've found on a few occasions that a dust spot has been a bit stickier than most, but I've managed to shift it by getting the nozzle to within a centimeter or so of the sensor.
Of course, this requires extreme care, since it's very difficult to give the bulb a good hard squeeze without the nozzle jerking a bit, with the risk of nasty consequences.
I've worked out a way of holding it that effectively braces the barrel of the nozzle against the edge of the chamber, which stops most of the movement.
So I can give it a good hard puff at close range - never failed to shift yet.
A bit scary though.
Nimitz
Posted 26/05/2008 - 14:36 Link
Thanks a lot all.
I will order it from cameraclean. Haven't been able to find a decent supplier in Denmark.
I think it is not dust - but pollen (is that the right word ? those sticky flower things). I tried to blow very close but have not used a brush. I don't have one. I might need one then.
If my memory is correct it happend after a macro day in the fields.....where I changed my macro for the zoom.
/Jesper
