Rubber Comin away on K20D
Posted 28/04/2009 - 12:23
Should have gone to "SRS!".......good luck in your quest for a replacement!........Ken
Posted 28/04/2009 - 12:38
Ermm..i did buy it from SRS. Should have gone to "SRS!".......good luck in your quest for a replacement!........Ken
It had a Memory card already in the camera and they said it was just to test the camera before shipment and not because it was a used model, but now i have that rubber coming away im not so sure.
Posted 28/04/2009 - 12:51
I'd suggest you phone them up, talk to them, and I'm sure they'll sort it out for you.
Posted 28/04/2009 - 12:53
It's not a common problem but it has been reported before so you're not alone.
The rubber covering down there is purely cosmetic (ie it plays no part in the weather sealing etc) and if the camera went back to Pentax it'd just get stuck down with a dab of Copydex. To save the time and hassle (and cost) of sending it back I'd just invest in my own tube of Copydex if I was you - only a pound or two and comes in most useful for any number of other DIY fixes (camera or otherwise).
Joining the Q
Posted 28/04/2009 - 12:56
I will call SRS and make sure they are OK with me doing that.It's not a common problem but it has been reported before so you're not alone.
Seems a lot of hassle to send it back and forth when thats all Pentax would do anyway.
Posted 28/04/2009 - 15:11
SRS will probably advise that you not try to fix it yourself, but that's what I would do anyway, rather than be without it for a while.
Copydex or other good contact adhesive is what I'd use.
Posted 28/04/2009 - 22:26
Sorry about that!......I'm sure they will sort it out!....as for sticking it yourself,I wouldn't go down that road in case it has to go back in future!. If you have done a "Self repair", they might just wash there hands of it.....rules of warranty etc, best to contact SRS and arrange for it to go back. As for the card in the camera,check how many times the camera has been fired, just to make sure you have a "New camera!"..........
Posted 28/04/2009 - 22:57
Hi Craig,
I was having a late night browse and saw this. Send it back to us and I will replace it and refund your return postage. If you need to speak to me then give me a call tomorrow (01923 226602)
Chris
Chris
For all things Pentax please visit www.srsmicrosystems.co.uk - anything not listed please email or call!
Follow us on Facebook
Posted 28/04/2009 - 23:01
What a star this man is!......The perfect retailer!......
Posted 29/04/2009 - 00:29
One can only imagine the horror and sleepless nights of having a rubbber slip off...but I digress.....had it start to happen on an old mz5 way back when, was hardly noticable and a little rubber cement fixed'er right up.
good one on srs for exchanging that one! chris rocks!
Posted 29/04/2009 - 00:37
Mike-P wrote:
My K10D did it a few weeks ago, bit of superglue on a needle tip and just a quick wipe under the flap and its now stuck down good as gold.
While superglue certainly does the job I wouldn't recommend it. It'll hold the rubber down but those coverings are designed to be peeled back (they cover access screws for the body) and if it's been super'd the cover will have to be torn. That's why Copydex is perfect; it makes a gummy seal that'll hold fast until you actually want it to come away with a scalpel blade... My K10D did it a few weeks ago, bit of superglue on a needle tip and just a quick wipe under the flap and its now stuck down good as gold.
I think I've spent too long renovating tatty old cameras
Joining the Q
Posted 29/04/2009 - 08:24
Well you could have told me that before I did it ... While superglue certainly does the job I wouldn't recommend it. It'll hold the rubber down but those coverings are designed to be peeled back (they cover access screws for the body) and if it's been super'd the cover will have to be torn.
Lanarkshire,
Scotland
Is this a common fault?
Its not bad at the moment but i dont think its going to get any better.
Approx half a thumb width (quarter inch), it looks as though it wasnt sealed properly during manufacture.
Also looking at the Place where i bought its website it seems im liable for any Carriage costs if i return it.
Bit unfair i think as i would only send it Special Delivery and that would probably cost me £10-£12.
