Remove circular polorising filter
Posted 23/08/2022 - 11:47
Try a small thin elastic band attached to the 'base ring' of the filter (or in my case a CPL), hopefully this should afford a better grip for the fingers! I have used this a few times and now leave the band attached.
Posted 23/08/2022 - 12:52
To add to loadoftripe's suggestion, I now use a thin O ring between the CPL filter and the lens so it never locks itself on again.
Easily available on the web, and for little money
Chris
Posted 23/08/2022 - 13:10
You can get plastic filter wrenches which I have used a couple of times, they are very cheap so worth keeping in your bag.
Posted 23/08/2022 - 16:21
+1 to this. I got a set a few years ago when using adapters to do unconventional things with expensive lenses (e.g. reverse mounting a Q-01 on the front of a DA*300mm). Hardly used, but when it was necessary to use one it worked like a dream. And I felt a lot happier using a purpose-made gizmo on expensive lenses than an ad-hoc thingy.You can get plastic filter wrenches which I have used a couple of times, they are very cheap so worth keeping in your bag.
Mike-P wrote:
A flip flop or slipper with a soft rubber sole has always worked for me, just press the filter into the rubber and turn (as long as it's not one of those variable things)
It's a polariser so presumably the front element rotates.A flip flop or slipper with a soft rubber sole has always worked for me, just press the filter into the rubber and turn (as long as it's not one of those variable things)
Posted 24/08/2022 - 00:25
I use an anti slip mat for limited mobility people. They "grab" onto anything that's on it. Just put the lens filter side on it, then "unscrew" the lens to get the filter off. Only caveat is that it doesn't work with polarizing filters. I use a "dab" of wax base lubricant on my filter threaads, it helps avoiding sticky situations.
Posted 24/08/2022 - 11:05
Thanks all, will try those, especially the elastic band.
Pentax K1-ii and MZ6
ONE UNITED Member
ONE UNITED Member
Posted 24/08/2022 - 11:56
That worked, shan't be putting it back on.
Thanks again.
Thanks again.
ONE UNITED Member
ONE UNITED Member
Posted 24/08/2022 - 15:07
Use an O ring on the filter thread, it does work
Chris
22 years
Handsacre
Came to register one of my lenses and cannot remove the filter listed in the title. For some reason it seems to be jammed solid on the lens.
Any tips on how to removeit?
Thanks.
ONE UNITED Member
