RAW Conversion with 150-500.
Posted 22/05/2012 - 09:21
Personally I sit in RAW edit for a long while, just playing about. I do click on the Auto settings to start with, both image and WB but then play with everything to see what works best. I even open Jpegs in RAW too but with the reduction in resolution to start they can turn out a bit iffy. I do save the cropping until I am in photoshop though.
As for the photo's don't be afraid of a shallower DOF as increasing the appeture allows a faster shutter speed, and can result in a sharper close up at distance. With nice bokeh in the background.
this was about 15-20 ft away
Taken with my K-x
Format was RAW+
F/5.6
1/1600th
ISO 200
focal length 90mm
link
saved before crop as a Tiff and after as jpeg resolution 240ppi
Hope some of this makes sense but all the images I took on my birds of prey day were wide appeture and fast shutter even the macros. link to the shots took below.
link
link
hope some of this helps
Taken with my K-x
Format was RAW+
F/5.6
1/1600th
ISO 200
focal length 90mm
link
link
link
Posted 22/05/2012 - 09:43
Are these massive crops? You should be getting sharper
pics with the 150-500mm. Loss of sharpness can be through
camera shake or not quite nailing the focus.
The processing looks OK.... maybe they could be sharpened
a bit.
a bit.
Posted 22/05/2012 - 09:55
I'm still not convinced Roger. I know you take good pictures. I've seen them taken with your other lenses.
I shoot RAW but don't see that it should make any difference to the final image on these except perhaps to the blown whites on the grebes head may have been worse if shot in jpeg.
Its a pity we live so far apart. I'd be really interested to have a go with yours and for you to have a go with mine. You need to compare your lens with someone who has one close by. There must be someone. Ask on here.
Good luck mate
Good luck mate
Posted 25/05/2012 - 14:59
1/400th sec at 440mm (equiv to 660mm in 35mm format) is probably pushing your luck handheld with shake reduction off. At least, it would be for me!
Posted 25/05/2012 - 23:23
Thanks, all.
WPC, the lens os was "on", the K7 sr was "off".
Alan, I've arranged a meet with brianfromwilts, who is local.
Mike, the wren image was, it turns out, a jpeg.
I must have changed to RAW halfway through the shoot.
The grebe image, below, is a non-processed jpeg from the raw file.
![Comment Image]()
[IMG]http://i1021.photobucket.com/albums/af340/rogerhlane/GCGchicksWREN028.jpg[/IMG]
![Comment Image]()
[IMG]http://i1021.photobucket.com/albums/af340/rogerhlane/GCGchicksWREN049raw.jpg[/IMG]
Please feel free to do with these as you will!
I'll be interested to see results/further comments.
Posted 26/05/2012 - 14:14
Grebes are sometimes soft because of all the water on their
feathers and the beak isn't always in focus.
Posted 26/05/2012 - 16:40
Mike, any advice for uploading bigger files, please?
roger.
roger.
Posted 26/05/2012 - 17:43
Sorry to be a pain, Mike......
I've downloaded Dropbox & the two files are on there.
I can't work out how to either copy them to here or to you/your e-mail.....????
R.
R.
Posted 26/05/2012 - 17:47
The Public folder lets you easily share single files in your Dropbox. Any file you put in this folder gets its own Internet link that you can share with others -- even non-Dropbox users!
Step 1: Drop a file into the Public folder.
Step 2: Right-click this file, then choose Dropbox > Copy Public Link. This copies an Internet link to your file that you can paste anywhere: emails, instant messages, blogs, etc.
That's it! To share your file, just send the link to a friend.
Posted 26/05/2012 - 18:02
Ta-Daaa!
![Comment Image]()
http://dl.dropbox.com/u/81654024/GCG%20chicks%20WREN%20028.JPG
![Comment Image]()
R.
Is that it???
R.
Is that it???
Wiltshire
First, A Great Crested Grebe, K7, 150-500, handheld, about 12 foot away.
Lens OS on, K7 SR off.
Iso 400, 1/400th. @ f7.1. F = 440mm.
[IMG]http://i1021.photobucket.com/albums/af340/rogerhlane/GCGchicksWREN049.jpg[/IMG]
And a wren, K7 & Sigma, monopod, about 40 foot away, quite a big crop.
Settings as above but 1/320th. @ f8.
[IMG]http://i1021.photobucket.com/albums/af340/rogerhlane/GCGchicksWREN028crop.jpg[/IMG]
Any C&C re improvement over straight jpegs previously posted or advice on conversion technique most welcome!
Roger.
