Rainbow - camera effect?
Oggy
Posted 08/11/2009 - 22:42 Link
This is a crop from a picture I took a few days ago.
[IMG]http://i217.photobucket.com/albums/cc222/Oggy3323/Rainbow.jpg[/IMG]
Not really worth C&C, but one curiosity. I know inverse concentric rainbows do occur in nature, but when I took the shot, I definitely could not see the second rainbow on the left hand side.
Is there any way this could be camera or lens related?
Daniel Bridge
Posted 08/11/2009 - 23:47 Link
No.
You just didn't notice the double rainbow, they happen quite frequently, and although a lot harder to see than the main rainbow, they're often there when you look for them.
Dan
Anvh
Posted 09/11/2009 - 12:29 Link
Like Dan says it's quite common.
It's a reflection of the rainbow itself, if you look the colours are the other way around.
From wiki
Frequently, a dim secondary rainbow is seen outside the primary bow. Secondary rainbows are caused by a double reflection of sunlight inside the raindrops, and appear at an angle of 50°–53°. As a result of the second reflection, the colours of a secondary rainbow are inverted compared to the primary bow, with blue on the outside and red on the inside. The dark area of unlit sky lying between the primary and secondary bows is called Alexander's band, after Alexander of Aphrodisias who first described it.
A third, or tertiary, rainbow can be seen on rare occasions, and a few observers have reported seeing quadruple rainbows in which a dim outermost arc had a rippling and pulsating appearance. These rainbows would appear on the same side of the sky as the Sun, making them hard to spot. One type of tertiary rainbow carries with it the appearance of a secondary rainbow immediately outside the primary bow. The closely spaced outer bow has been observed to form dynamically at the same time that the outermost (tertiary) rainbow disappears. During this change, the two remaining rainbows have been observed to merge into a band of white light with a blue inner and red outer band. This particular form of doubled rainbow is not like the classic double rainbow due to both spacing of the two bows and that the two bows share identical normal colour positioning before merging. With both bows, the inner colour is blue and the outer colour is red.
Stefan
K10D, K5
AF-540FGZ
