Problems
What lens were you using? Apparently (and I don't know why) using a manual lens with the camera left in AF mode can cause this glitch, but if not try the usual's just in case (but don't hold your breath)- batteries, reset camera to default settings, latest firmware, but if all else fails buy an external flashgun and use it in the hot-shoe.
An external flash will invariably give better performance than the on-board, but is less convenient. Lots of people here go with Yongnuo as a cost effective brand, or Metz, and either will offer a range of products and prices.
You might ask the retailer to get it repaired. If you bought from a Pro-centre your warranty will be two years. If not, you could try to rely on the Sale of Goods Act -- ie, essentially, an item costing what yours cost shouldn't have one of its features pack up after 13 months. There is plenty of guidance on the Internet to the rights you have under this legislation. It is not always easy to enforce, though, particularly if you bought from a retailer such as Amazon.
Bought new from well known camera shop - has worked perfectly for 2 years - but not now.
Or are you possibly not waiting long enough to allow the flash to charge, so during that time the shutter won't release? If that's the case I'd look at faulty batteries as a possible cause. Two years for a battery might see it past its best, depending on usage.
12 years
