Problem with downloading from my K7 into CS3
Posted 12/08/2011 - 15:15
Hi Russ,
Unless you've told your camera otherwise, it has probably saved the RAW images in PEF which your photoshop can't read.
I did this on my k-r when I started using RAW and had to load the pictures onto the pentax processing package that came with the camera and save them in DNG.
There might be a possibility of updating your CS3 to accept the PEF files though.
Kind regards
Charlotte
Kind regards
Charlotte
Posted 12/08/2011 - 15:34
Hiya, recently had the same problem but with CS4, set the K5 to save as .dng and that'll solve the problem.
Chris
Posted 12/08/2011 - 17:30
There is a free DNG Converter available from the Adobe site which will convert all your previous PEF files.
DNG is the Adobe standard raw format and hopefully is very future proof for long time compatability.
Friendly Regards
Graham
Graham
Posted 12/08/2011 - 18:03
Thanks all. This has fixed my problem.
Russ.
"There are no rules for good photographs, there are only good photographs"
Ansel Adams
Russ.
Ansel Adams
Posted 13/08/2011 - 09:46
Graham,There is a free DNG Converter available from the Adobe site which will convert all your previous PEF files.
I had a look for this but could not find it. is it a stand alone program or a plug in for Photoshop?
Russ.
Ansel Adams
Russ.
Ansel Adams
Posted 13/08/2011 - 14:57
Thanks all, I am now downloading my files and have converted all the previous ones with you help
Russ.
Ansel Adams
Russ.
Ansel Adams
Benfleet Essex UK
Russ.
Ansel Adams
