Prime lens focussing problems
Posted 08/02/2009 - 20:44
womble wrote:
Best wishes, Kris.
Missed that, sorry.
Miniman wrote:
I have done comparisons at all apertures with 2 manual + 2 autofocus lens manually. Only the manual primes give me problems. Both primes are bayonet mount. I have used o right angle magnifier on the view finder, I have checked the diopter setting. I am now going to set the lens/newspaper distance according to the barrel markings and try Bob's idea.
Mannesty wrote:
You still haven't answered mikew's question. Are these M42 screw thread primes, or bayonet?
Bold my edit.You still haven't answered mikew's question. Are these M42 screw thread primes, or bayonet?
Best wishes, Kris.
Posted 08/02/2009 - 20:45
Hi Everyone,
Just done another newspaper test using Bob's idea.
Tools: 1 Manual Pentax prime, 1 Chinon manual prime, 1 18-55 mkII autofocus, all used manually.
Test: Tape newspaper to wall, set camera on sturdy tripod, set front element 1.2 metres from said newspaper. Also as final test set autofocus to autofocussing to compare.
Results : When lens set on barrel to 1.2 metres the results were excellent. When barrel spun and returned slowly until green hexagon lights, the results were basically so, so poor. When this was checked against the barrel distance markings it was found to be quite inaccurate. Either way the barrel was turned the inaccuracy was either more or less than the 1.2 metres. This seems to indicate that on the prime lens the focussing hex in the viewfinder is not accurate manually,yet is accurate when used manually on auto lens.
Many thanks for all your help, I am now going to take up painting.
Regards, Richard.
Regards, Richard.
Posted 08/02/2009 - 20:56
How far out would you guess it to be? Measuring from the front of the lens would make that measurement out to the tune of the lens length plus flange-to-sensor distance. Unless things have changed, the scale on the lens is the subject-to-film distance?
Posted 08/02/2009 - 20:57
mikew wrote:
Tsk Kris ye of little faith the bayonet bit was added as an edit after the reminder from Mannesty!
Pity they weren't screw fit then we could blame the converter!
Opps I forget that we can edit our posts. Sorry Peter Tsk Kris ye of little faith the bayonet bit was added as an edit after the reminder from Mannesty!
I had guessed the line we were going down was a dodgy converter.
I wonder if this is related to the old front/back focusing chestnut? Presumably the hexagon is part of the AF system even if it is being used to help focus an old manual lens?
Cheers, Kris.
Posted 08/02/2009 - 21:43
That's right and why it's worth experimenting to find what actually works best.
~Pete
Posted 08/02/2009 - 22:56
Sounds like a katz-eye (or equivalent) split screen focus screen is the way to go.
Posted 09/02/2009 - 19:36
Hi, this may be true, but given that the tests focussing manually using the green hex were quite a way out both sides of the 1.2 mtr mark I don't think this is the main issue. Using the hex I had differences of up to 100 mm either side of the 1.2 mtr mark. This demonstrates my inability to focus accurately using the green hex. I need a split screen or an AF lens. This getting old is becoming a problem.How far out would you guess it to be? Measuring from the front of the lens would make that measurement out to the tune of the lens length plus flange-to-sensor distance. Unless things have changed, the scale on the lens is the subject-to-film distance?
Many thanks, Richard.
Posted 09/02/2009 - 19:39
Richard
I have found that the green hexagon is hit or miss for manual focus confirmation, but not by the amounts you are seeing.
Bur split prism screen is the way to go for sure.
Posted 09/02/2009 - 20:20
Ahh, the green hex when using my Pentax-A 28-80 is miles out too, as it is with the Sonnar, Flek and Helios. I think if you are going to use manual focus, you need to manual focus. If you are going to turn the ring until the camera says stop, then you might as well let it turn the ring
I like the as-supplied focus screen for manual focussing myself, but tastes and eyesites differ. How are things when you completely ignore the annoying hex?
Worcestershire
