Mk II Kit Lens
Posted 08/02/2009 - 16:47
I know it can't really be compared with the MkI version that I had, but I grew to really dislike my kits lens. It just didn't feel nice to use. I ended up selling it with the K100D body. It was sharp and contrasty and performed flawlessly, but it just lacked something, which I can't really put my finger on beyond saying "we didn't get on very well"
Bizarrely, I get on great with the old 28-80 manual focus lens. Wide open it can't touch the old 18-55 and only gets good at f8 and beyond.
Maybe it's a 'character' thing rather than a technical thing
Posted 08/02/2009 - 17:06
18-55 II is sharp and feels nice to use to me. It's handy that it doesn't obscure the pop-up flash as well. My only complaint is that it's rather slow at the long end.
~Pete
Posted 08/02/2009 - 17:13
No complaints about my Mk II either, it's been out and about in the snow and produced some sharp clear shots. This was taken with it.
As a 'standard' it has to be the best supplied on ANY camera.
Cheers, HG
PPG entries.
PPG entries.
Posted 08/02/2009 - 19:19
I've been quite happy with my Mark I lens (the foggy trees photos were taken with it for example). So much so that when faced with the choice of replacing it with a DA 16-45mm or DA* 16-50mm, or buying something utterly different and keep using the kit lens, I went for the utterly different. The first time I got the 50-135mm and the second time the 12-24mm. I have a horrible feeling that next time I walk into SRS thinking of getting one or other of those replacement zooms, I might just walk out with the 43mm Ltd instead The only thing that bugs me sometimes is the f/5.6 at the long end.
John, your nice new shiny K20D seems to have some dust on the sensor already!
Best wishes, Kris.
Best wishes, Kris.
Posted 08/02/2009 - 19:32
Nice shot, John.
What lighting did you use :
Hyram
Posted 08/02/2009 - 21:10
A large window gives nice even illumination. Sometimes I switch on the room lights to given some tungsten coloured highlights, but not if it's for eBay.
Posted 08/02/2009 - 21:25
Whats the markII kit lens like compared to the 16-45?
Posted 08/02/2009 - 21:45
Equally as sharp, almost as fast at 42mm (f4.5), but distortion and vignetting is greater at the wide end.
~Pete
Posted 09/02/2009 - 11:13
I'm getting more and more impressed with my kit lens, especially since reading so much doom and gloom about it on here and other forums...
Sure, it's not really fast enough to be much use in poorly lit rooms, but i've had some good success with shots like these
Pentax K20D, Pentax 18-55mm II, Pentax M 50mm 1: 1.7, Super Paragon 1: 2.8 24mm Macro, Pentax smc DA 50-200 mm F4-5.6 ED
my flickr
buy images
my flickr
buy images
Posted 09/02/2009 - 11:48
My verdict, based on limited use, is that it is very sharp in the centre, but not such a great lens at the corners. It is considerably less sharp, and the corners are quite big, if you see what I mean. I would only upgrade if I was certain that any new lens was going to be a lot sharper in the corners.
Vaguely interestingly, I went out at the weekend with the kit lens on my K20D and a mate took his new Canon G10. We did a couple of test shots of the same scene (mine at F8 and ISO200). The kit lens on the K20D was clearly sharper in the centre of the picture than the G10, but there was little to choose between the two images at the corners. There was also some CA at the corners, but only really a problem at 100%.
Cheers,
Spencer
K20D | DA 18-55 II | FA-J 75-300
Spencer
Posted 09/02/2009 - 12:41
I compared 18-55 II, 18-55 I and 16-45 on a K10D. 18-55 II and 16-45 seemed equally sharp at the centre and corners to me; 18-55 I was softer at the corners and borders.
Sorry I didn't keep the test shots.
~Pete
Posted 09/02/2009 - 21:39
24 years
Tyldesley,
Manchester
[IMG]http://i240.photobucket.com/albums/ff250/johnriley1uk/028-Voigtlander-Vito-B.jpg[/IMG]
I find this lens very useful for pictures of items for eBay because of its close focusing and also the quick shift. I use AF for these images, but tweak the point of focus manually.
