PKA/RICOH LENSES
Posted 24/10/2006 - 01:17
The pin gets stuck in the hole in the mount where the AF shaft is located. No pin = no problem.
Posted 24/10/2006 - 08:34
Thank you
Posted 25/10/2006 - 03:52
Ricoh lenses aren't at all bad, if it's an easy job to remove the pin, I should think it would be well worth the effort
Posted 25/10/2006 - 08:22
The lens is a a Vivitar 2xmacro converter which has variable magnification up to 1:1 depending on the lens used. It works well and is worth saving I think
I have also have a Vivitar 28mm f2.0 which needs the same treatment. It should be a good standard lens on the istDS.
20 years
