Pentax updates
Posted 26/11/2009 - 09:09
Me neither!
Posted 26/11/2009 - 09:33
Just select k7 from the drop down menu then you can see the updates. Thanks for the heads up.
Pentax K-7 | Pentax D-BG4 Grip | Samsung GX10 | Samsung SBG-D1V Grip | Samsung D-Xenon 100mm Macro | Pentax DA 18-250mm | Pentax FA-50mm | Sigma 10-20mm | Samsung D-Xenon 18-55mm | Samsung D-Xenon 50-200mm | Metz 48AF-1 | Manfrotto 055XPROB | 322RC2 Head.
Posted 26/11/2009 - 17:18
pentaxian450 wrote:
There is a new version of the Pentax Digital Camera Utility 4 as well as a codec update available. You must have the original Pentax DCU 4 already installed to take advantage of it.
Here it is: http://www.pentax.ca/support/digital/index.php
Enjoy!
Unlike the previous updates, the installer asks for the CD even if you give it the /s option. You can get around not having the original CD and not having the older software installed, by burning a CD with the name S-SW90. It doesn't matter what is on the CD, it can be blank if you want.There is a new version of the Pentax Digital Camera Utility 4 as well as a codec update available. You must have the original Pentax DCU 4 already installed to take advantage of it.
Enjoy!
You can download the updated software from the main Pentax site (I did). - LINK
Posted 26/11/2009 - 17:27
Can anyone say if this is better with the K20D please?
Posted 26/11/2009 - 18:54
Fine with any Pentax DSLR. Still not quite class leading software, but much easier and loads better than the previous version. Now has proper batch processing and many of the features of the latest Silkypix 4 software on which it is based.Can anyone say if this is better with the K20D please?
Image quality is very good and will give the traditional Pentax colours, i.e. identical to the in-camera JPEG's
Great value, i.e. FREE!
Posted 26/11/2009 - 20:13
Thanks Richard. Just to clarify, if you DO have the older Pentax Digital Camera Utility 4 software installed, will the update still require the CD? If so, where on the CD do you burn 'S-SW90' please? In a text file, as a volume lable, what?
Posted 26/11/2009 - 22:01
Does not work with V3 as supplied with the K20.
Posted 26/11/2009 - 22:20
Thanks for the link, as I'm buying the K7 tomorrow I downloaded the manual for now,
Jack.
Jack.
Posted 28/11/2009 - 20:50
JohnX wrote:
I believe that you still need the disc. I didn't have it installed so I cannot confirm this, but it has been reported by others who do.RichardDay wrote:
Thanks Richard. Just to clarify, if you DO have the older Pentax Digital Camera Utility 4 software installed, will the update still require the CD? If so, where on the CD do you burn 'S-SW90' please? In a text file, as a volume lable, what?Fine with any Pentax DSLR. Still not quite class leading software, but much easier and loads better than the previous version. Now has proper batch processing and many of the features of the latest Silkypix 4 software on which it is based.
S-SW90 is the Volume label.
The disc doesn't need any content, just the label.
Posted 29/11/2009 - 00:59
If you have the Pentax Digital Utility 4 installed on your computer, you don't need the disk.
Posted 29/11/2009 - 12:59
Mannesty wrote:
But if you haven't got a K-7, you shouldn't have it installed
I won't tell if you don't tell!
North of Montreal,Quebec,
Canada
Enjoy!
