PENTAX REMOTE Assistant v3.51 and Vista
Posted 07/10/2008 - 18:57
hoshisato wrote:
PENTAX REMOTE Assistant v3.51 works fine on Windows XP but I can't get it to recognize my K20D camera on Vista at all. Does anybody here have the same problem or has a solution?
I don't know about the K20, but PRA 3.51 works fine with my K10 and Vista. PENTAX REMOTE Assistant v3.51 works fine on Windows XP but I can't get it to recognize my K20D camera on Vista at all. Does anybody here have the same problem or has a solution?
Posted 07/10/2008 - 19:00
I got it to work by checking the "Run this program as an administrator" box in the properties of the PENTAX REMOTE Assistant shortcut under the Compatibility tab.
I was going to delete this post, but I figured that others might have run into the same issue.
Cameras: Pentax 67II / 645NII / K20D / MZ-S / MZ-3 / ME
Gallery: Hans ter Horst Photography
Posted 07/10/2008 - 19:07
Glad to hear you have solved the problem I got it to work by checking the "Run this program as an administrator" box in the properties of the PENTAX REMOTE Assistant shortcut under the Compatibility tab.
Posted 08/10/2008 - 01:09
That's also what I have to do. Glad you found the solution to your problem.
Posted 23/05/2009 - 12:48
Spent an hour or so trying to get PRA to recogognise my K20 to no avail. So thought I would search the forums, and hey presto, now I'm connected.I got it to work by checking the "Run this program as an administrator" box in the properties of the PENTAX REMOTE Assistant shortcut under the Compatibility tab.
Thanks for for your post !!
K20D/DBG2 | Pentax DA 18-55/3.5-5.6 AL| Tamron DiAF 70-300/4-5.6 | Pentax A 28/2.8 | Tamron ad2P/KA 28-70/3.5-4.6 | Tamron ad2P/KA SP90/2.5 +macro 1.1-1.2 extn | Teleplus KAX 2x | Vivitar PK 2x22 |Metz 58AF1 Flash| Canon FD Bodies: T90; T70 | FD Lenses C50/1.8; Vivitar S1 70-200/3.5; Sigma 400/5.6; Vivitar AT4 ext tubes; CFD 2xA extender; Tamron ad2CFD 28-70/3.5-4.5 | Cullman CX35 + offshoe cables |
Posted 23/05/2009 - 18:35
you guys are the best. I have a huge photoshoot today and I though I would try it Remote assistant and I spent a good hour redownloading the program.
I should have checked here first.
A+ comments
A+ comments
Posted 01/02/2010 - 11:04
Thanks to the "Run as administrator" tip I am running Remote Assistant successfully on my Windows 7 laptop.
One thing I did notice, which may or may not be helpful, or general was: if I inserted an SD card into the SD slot on the computer and used the "ready boost" facility to improve computer performance then Remote Assistant would no longer find and operate the camera. When I remove the ready boost functionality the camera re-appeared.
Flickr feedback always appreciated: https://www.flickr.com/photos/robheath/
Pentax K-3/DA 18-135mm WR/DA 18-250mm/DA*50-135/Tamron 70-300/AF360FGZ/Manfrotto 055XPROB/a few other bits and pieces
Posted 27/02/2010 - 00:10
Had PRA working fine with W7 Ultimate x64, after setting to 'run as Administrator', but now I've added 'XP Mode' via the 'Virtual PC' it's not playing any more !
Seems to be ignoring the USB connect as it blinks slightly when I turn camera on, then just sits idly waiting for me to connect !?
Anyone help !?
Anyone help !?
Posted 27/02/2010 - 02:20
As the old story goes, a guy walks into a doctors office and says "doc, my arm hurts when I move it this way." Doctor replies "Well then, don't do that".
If it is working under Win7, why run it under XP mode?
I assume you mean compatibility mode. But still why fix it if it ain't broken.
If you mean simply that you have Virtual PC running on your Win7 and that XP is running within the Virtual Box, I have heard of issues with VirtualPC v.s. USB devices. Can't recall anything specific, but Google for that and you may find how to fix it, or perhaps that you should just go to VMWare or other solution.
Still, in the end, I have to ask why -- if it works under the native Win7 to begin with.
Posted 27/02/2010 - 09:44
I think u missed the point ! Completely !! As the old story goes, a guy walks into a doctors office and says "doc, my arm hurts when I move it this way." Doctor replies "Well then, don't do that".
It DID work in W7, but not now I've added Virtual PC and XP mode ! I added XP Mode for an old scanner
Posted 23/12/2010 - 15:34
Thank You for leaving this post up it was very useful.
Posted 23/12/2010 - 21:45
Not sure how I missed your point. You seemed to confirm my questions and statements.I think u missed the point ! Completely !!
- If you have Win7 working, why run it under XP, especially under a VM?
- VMs can have issues with USB devices. We run into such issues on a regular basis with the software we write and have to periodically verify against actual hardware.
Are you saying since you added VirtualPC and XP mode that it no longer runs natively under Win7?
That sounds problematic, but some reason I'm not surprised. Win7x64 has lots of issues with devices (not Win7 or Microsoft's fault - as easy as it would be to blame them - but x64 has some strict requirements for drivers that just might not be completely supported. Still, if it was working on Win7x64 to begin with, not sure why it would have stopped.
Posted 24/04/2011 - 02:13
I cannot even get Pentax remote Assistant to load onto the computer running windows 7. I have tried opening it as Administrator with no luck. Do you have any idea of how to load the program in the first place?
UK,
London area
