Pentax Optio 33Lf - SD card compatibility
Posted 11/04/2007 - 14:36
Ok, this may help someone in future...
Dear Sir/Madam,
Thank you for your enquiry.
Unfortunately the maximum amount of memory this camera can take is 512MB.
Therefore 2GB or higher cards will not work.
I hope that your question has been answered to your satisfaction.
Should you have further questions regarding this matter, please do not hesitate to contact us again.
When replying, please make sure this email is included.
With kind regards,
Wim van kleef
Pentax Digital Camera Support Team
Dear Sir/Madam,
With kind regards,
Wim van kleef
Posted 11/04/2007 - 14:41
Anyway... if someone tests a 1GB or 2GB SD with his Pentax Optio 33Lf please feedback
Posted 12/04/2007 - 11:00
More info:
Pentax no garantiza compatibilidad de tarjetas con ninguna marca o modelo, pero si que hay una consistente compatibilidad de mas de 512MB con tarjetas de memoria de PQI, Panasonic, SanDisk y Toshiba.
Atentamente,
Reflecta S.A.
Atentamente,
Reflecta S.A.
Pentax does not guarantee card compatibility with any brand or model, but there is a consistent compatibility with > 512MB memory cards of PQI, Panasonic, SanDisk and Toshiba.
Kindly,
Reflecta S.A.
Kindly,
Reflecta S.A.
Pentax Optio 33Lf
Posted 15/05/2008 - 13:56
I was so close to binning my camera yestarday when I found this site. It has been freezing up for ages and I thought I would try the great and wonderful web for an answer. I had put a 2g card in and did not connect it to the problem. Took it out and put the 512 card back in, works fine now.
Thank you so much
Margaret
Thank you so much
Margaret
Spain
I have tested recently a Dane-Elec 2Gb SD like this
but sometimes it gets freeze on startup (once on it works perfectly, I take hundreds photos without problems and also I recorded some videos).
My cam has the lastest firmware (v1.01) but I don't know if this SD is defective or Optio 33Lf doesn't support 2Gb cards.
On the other hand, on lexar's website (http://www.lexar.com/2gbsd/index.html) Optio 33Lf appears as compatible with their 2Gb SD...
Thanks.
