Pentax Movement in Camera
Posted 19/09/2009 - 13:05 - Helpful Comment
Carly wrote:
could this be the stabalising mechanism?
Yep.could this be the stabalising mechanism?
It's the sensor sliding from side to side. There's a slight noise when it slides, and a faint thud as it reaches the limit of its movement.
All the Pentax dSLRs with shake reduction do this, as far as I know. Completely normal.
Posted 19/09/2009 - 13:32
Hi ChrisA
Thanks for the reply, your input has been most helpfull.
I've had my Pentax K-m for a short while after taking forever to switch over to digital photography.
Decided to stick with Pentax due to the backward compatibility with older lenses.
One question to all digital SLR users, when I slowly rotate the camera there's a slight movement inside.
This is more noticeable when the camera is off, I've removed the batteries and the lens, could this be the stabalising mechanism?
Oh by the way, there's no problem with the camera taking pictures.
Regards,
Carl
