Pentax Digital Camera Utility 5 (V5.4.1) problems
Posted 01/01/2016 - 01:23 Link
The reason I threw out the Pentax utilities was the sheer, boring waiting time to load, process and save just one image. It took an eternity! There is a difference between the outputs but unless you are going to produce a whopping great poster it hardly matters.
My general M.O. with FastStone is to load the RAW and go to Levels (CTRL+L). If there is a great gap on the right of the histogram, I reduce it with the slider and then adjust the contrast with the middle slider button. Crop (X), resize (CTRL R) and sharpen as required (CTRL U). (CTRL S) saves it. As you can see, there need not be a lot of mouse work at all.
My page on Photocrowd
microlight2010
Posted 02/01/2016 - 11:13 Link
@Steve: in the Settings (F12)/RAW tab, I have 'view RAW files in' box checked, with 'actual size (slow)' selected, which I'm assuming means that it's displaying the decoded RAW? As with DCU, FS takes a few seconds to display the image in the preview box at bottom left, presumably because of the decoding process. I don't have an issue with DCU5 as I've habitually used PDCU4 since I got the original K-5 - good thing really, as I have to use it for generating pixel-shift photos!
K-3II - HD DA20-40 Limited, HD DA55-300PLM, SMC DA10-17 Fishy, AF201FG Flashy
SteveLedger
Posted 02/01/2016 - 11:36 Link
Yes, I think you are correct.
whyhaveone
Posted 19/01/2016 - 00:28 Link
Well I've tried the full trial version of Silkypix and have similar problems - plus I just do not like it, it's too complicated for me.
For the moment, Faststone works fine and does what I want.
SMC Pentax-DA L 18-50mm F4-5.6 DC WR RE; SMC Pentax-DA L 50-200mm F4-5.6 ED WR; SMC Pentax-D FA 100mm F2.8 Macro WR;
HD Pentax-DA 55-300mm F4.5-6.3 ED PLM WR RE; SMC Pentax-FA 80-320mm F4.5-5.6; HD Pentax DA AF Converter 1.4X AW.
The 50-200 and 80-320 will be sold assuming I like my new 55-300.
SteveLedger
Posted 19/01/2016 - 00:30 Link
Give RAWTherapee a shot. It's free.
whyhaveone
Posted 07/02/2016 - 23:28 Link
Currently trialing ACDsee Pro 9, it Works without any computer glitches.
Still like Faststone as a browser.
I'll now have to give RAW a go.
