Pentax DA50mm inconsistent focusing speeds
AlJones2402
Posted 02/02/2016 - 13:34 Link
linkHi All,
I would like to ask if anyone has experience with the DA50mm f.18?
I have noticed that this lens on my k3ii has inconsistent focusing speeds compared to my other primes and would like to know if others report the same?
It appears to start off slow and then gradually speed up when running through the focus range where as my FA 50MM and DA35mm are consistent from start.
Lens supplied from SRS and this is the 2nd one that has just arrived and behaves the same as the previous one.
Also I notice it's not as near as sharp as the FA50 and DA35mm.
Any feedback appreciated.
Links to YouTube:
link
link
Edited by AlJones2402: 02/02/2016 - 13:37
smc
Posted 02/02/2016 - 21:06 Link
Mine has been fine on a K5 and K5iis. Can I suggest trying a different body or a third lens, to eliminate an issue with the particular camera body you are using.
AlJones2402
Posted 03/02/2016 - 15:39 Link
Hi Smc,
Thanks for the response. I have tried it on the K5iis and it responds the same as on the k3ii.
As in the video links. It starts off sluggish and gradually increases in speed. Both the 35mm and FA50 are consistent throughout on both cameras.
The mind boggles!!
I don't appear to be having much luck.
I bought a k3ii deal with the 50mm and a DFA 150-4 50mm lens.
The 1st k3ii delivered was faulty and had to be returned for a replacement.
The 50mm was faulty and had to be replaced.
I'm glad the DFA 150-450mm appears to be working or I think I'd have lost all faith in the brand!! 😱
davidstorm
Posted 03/02/2016 - 21:00 Link
I was lucky enough to win a DA50mm F1.8 in a recent competition and have used it on my K-5iis, but not yet on my K-3.
What I've found so far:
- It is very sharp, even at F1.8 and is much better than a FA50 1.4 I used to have
- It focusses quickly, have not noticed any speed variation across the focal range
- It focusses accurately, even in near darkness and at F1.8
Don't know if this is any help!
AlJones2402
Posted 03/02/2016 - 21:07 Link
This what I expected!!
Surely I can't be that unlucky to be dealt a 2nd duff lens!!
David would it be possible(if you don't mind me asking) for you to post a video like my tests of the lens running through it's focus range several times on your k3ii for comparison purposes.
davidstorm
Posted 03/02/2016 - 22:03 Link
Here you go Rob:
link
Let me know if you can't link to it.
BTW, I did notice when doing this test that my K-5iis focusses faster with the DA50 than the K-3 does. Also please bear in mind the test was in dim light (it is quicker in good light) and my K-3 is a Mk1, not a Mk2.
PS it's my son's youtube channel, not mine!!
Edited by davidstorm: 03/02/2016 - 22:04
AlJones2402
Posted 04/02/2016 - 15:27 Link
davidstorm wrote:
Here you go Rob:
link
Thanks for the video David.
This to shows that there is variations between camera motor ability or lens build?
It does appear slower in this video and agree it runs faster on my K5iis and marginally faster(well faster but gains in speed) on the k3ii?
But even though it's slower in this case the speed looks consistent.
Confused!!
davidstorm
Posted 04/02/2016 - 22:20 Link
Hi Rob
Yes, the speed is consistent, I didn't notice it being quicker or slower from one end of the focal range. I'm out on Sunday with the Pentax crew and will use my K-3 with the DA50 attached. I will let you know how it gets on outside in good light, I expect no problems will be found.
I too am a bit confused that my lens doesn't exhibit the same behaviour as yours. Also confusing is why it is slower on the K-3 than it is on the K-5iis, as this is not the case with my other lenses! The only conclusion I draw from this is that my lens is consistent in focussing speed from both ends of the focal range, but differs in performance on different camera bodies. I suspect you have an issue, but I don't know if it's with your camera or your lens.
AlJones2402
Posted 05/02/2016 - 10:09 Link
Both the K5iis and k3ii operate fine with all other auto focus lenses I have present.
It just appears strange thaty da 50mm gradually increases in speed working through the focal range but operates virtually the same on both camera's unlike yours where one is slower than the othe
The mind boggles!!
I have emailed Srs to ask for their professional opinion in hope they can shed some light on this.
Thanks again for you input.
microlight2010
Posted 06/02/2016 - 22:05 Link
Hi Rob. Sorry to hear about your problem. I got a free 50/1.8 when I got my 20-40 Limited from SRS, and it's a great lens. The throw is much greater than the other plastic fantastic 35/2.4 and the focusing ring is tighter, but it focuses snappily and reliably on both my K-3II and K-5 and like the 35 is sharp as a tack. If you've tried two copies and are getting the same results then hopefully it's not the K-3II - but then it's OK with other lenses... Odd.
K-3II - HD DA20-40 Limited, HD DA55-300PLM, SMC DA10-17 Fishy, AF201FG Flashy
Edited by microlight2010: 06/02/2016 - 22:08
