pentax and nikon hotshoe
Posted 29/02/2016 - 23:03
For a first response answer: They don't. You HAVE to buy a Pentax HSS capable flash to enable the HSS mode.
Others will be along shortly to give more accurate answers...
Posted 01/03/2016 - 00:02
thanks for your help
i have the K3 and a metz 64 AF1 and cannot get it to fire with the triggers i have.
can you recommend triggers that even sync to 1/180 sec?
just looking for something that i can fire the flash and camera by remote control.
cheers
cheers
Pentax K3 Pentax SMC-FA 50mm 1.4
Pentax Kr Pentax SMC D FA 100mm F2.8 Macro
SMC DAL 18-55mm Pentax SMC DA 18-270mm F3.5-6.3
SMC DAL 55-300mm Pentax DA 15mm HD F4ED AL
SMC Pentax-M 1:2.8 28mm
Posted 01/03/2016 - 00:35
Hi balsembi, we might need more information on the triggers you have and how you are setting things ...
The Metz flash you have is a dedicated system model and so it will work wirelessly with the K3 via optical signals from the camera built-in flash. The camera remote control can be used to fire the camera and flash as well.
Is this what you want to do? Or are you needing to use radio triggers for some reason? Apart from the Acon products, radio triggers systems mean manual flash control only, and as Richard has pointed out, no HSS via radio.
Posted 02/03/2016 - 01:11
hi mcgregni
i currently have the aputure trigmaster ii which work perfect wiyj my yognuo speedlites. just cant get them to work with my metz
i basically just want to fire the metz flash wireless off camera withouse firing it with the pop up flash
thanks
thanks
Posted 02/03/2016 - 18:14
Perhaps a picture or two of the set-up plus details of the settings you're using may help to prompt some ideas. I assume the connection to the camera hotshoe and Metz seem tight?
It may be that the support forum for the triggers (if there is one) may have more specific knowledge available. It doesn't sound as if the problem concerns the camera as it does fire for the Yongnuo flashes......
Posted 02/03/2016 - 19:14
yes thank you, ive tried the forums but nobody is sure. luckily, the camera show ate the NEC is on in a few weeks and i'll be talking to metz and pentax there see if they can advise. hopefully i'll get to try before buy some triggers there.
but many thanks
but many thanks
Posted 03/03/2016 - 09:36
The Metz will need a receiver attached. The newer Yongnuos have a built-in receiver.
None of this will enable HSS off camera.
i was wondering if anyone knows if high speed flash triggers will work on the pentax hotshoe?
the hotshoe plates look pretty similar
