optio wg1
This topic has a poll - login to enter
Posted 09/03/2013 - 15:59
i would expect at least 5 years min.......
pentax says in add "Optio WG-1 definitely stands for the ideal choice for those active photographers who shoot pictures in demanding outdoor conditions, thanks to its tough construction" so would expect more use than 5 times..Waterproof to 10 meters so might you think pentax might think at some point it might get wet after all upto 10 meters in water .... Now here is the point claims" WATERPROOF " not weather resistant....
Shockproof to 1.5 meters coldproof to -10°C crushproof to 100kg..
Might think johnsons photopia would know that it is waterproof ... so there should be no
water damage .... I would speak to trading standards as well....
k-5 IIs, Pentax 60-250, 17-70, 100macro WR, 50mm F2,
AF50 F1.4, Siggy 10-20, Siggy 100-300 F4, ..Pentax Af 160 ring flash
Posted 09/03/2013 - 16:11
Welcome to the site. I hope you get a satisfactory resolution. It must be almost inevitable that some consumer-grade underwater cameras (in particular) will malfunction. However annoying, to the individual who has such a faulty camera, it may be just one of those things. If the camera has been treated well (as I'm sure yours has), you might reasonably hope for some understanding - though it's a puzzle that the seals are intact yet water got in. Col55.. suggests trading standards. that's extreme at this point.
Posted 09/03/2013 - 17:01
I would pursue it further. The only possible get-out clause is the one we all (me too) ignore that tells us that seals should be serviced every 12 months to guarantee the camera stays waterproof. This also applies to waterproof watches.
Just go back to JPS and/or Pentax and see what they will do. If the seals are OK, then any water damage must arguably be a fault.
Posted 09/03/2013 - 17:36
Your experience may not be that unusual. I am on my third 'tough' waterproof shockproof compact (various brands - none of them Pentax). The longest any of them has managed was 3 years before becoming faulty and I don't think I treat them badly - just routine holiday use. I now view this type of camera as a disposable holiday accessory - use until it breaks then throw away.
Regards, Philip
Posted 11/03/2013 - 23:13
Thanks all for comments,still waiting for Pentax to get back to me.....
Posted 12/03/2013 - 17:11
Expect a good wait, i think they take there time...
k-5, K-5ii,60-250 f4, 50 f1.4 af,17-70 f4, 100mm macro wr,siggy 10-20 siggy 100-300f4
13 years
