Off-camera flash bracket advice?
Mannesty
Posted 02/09/2010 - 08:56 Link
gartmore wrote:
Peter, I have no experience of the 500FTZ, why do you think it is more versatile?
For general use it's probably no more versatile than the AF400T actually, but:-
It has an AF assist light, auto zoom head, strobe effect (multiple flashes), and it can be mounted to a camera faster than an AF400T if needed. Of slightly lesser significance is the fact that it has a digital interface to the camera whereas I believe the AF400T is analogue.
Edited by Mannesty: 02/09/2010 - 08:58
gartmore
Posted 02/09/2010 - 12:21 Link
Dangermouse wrote:
I just don't see much point in buying something like an AF400T when I can't use anything other than the manual mode.
Not so, the AF400t also has 'Auto' mode and has its own sensor which measures the light reflected back by the subject.
I find this more reliable than P-TTL quite often.
gartmore
Posted 02/09/2010 - 12:22 Link
Thanks for that. Not going on ebay ever again, honest...
Mannesty
Posted 02/09/2010 - 12:34 Link
You want one really. Did I mention it's a tad more powerful than the AF400T? There was also a battery pack made for it to facilitate faster recycling.
Just picture one sitting on top of your Hot Shoe Grip . . . .
gartmore
Posted 02/09/2010 - 12:50 Link
Some people collect lenses, I seem to be collecting flasguns and TBH I dont really use them that much. The 400s are for weddings mainly, one as a backup, and are great with their wide angle adapters for (over) lighting white studio backgrounds. I used the 360 a lot at a wedding at the weekend where I was a guest. Quite funny really using the set up in the pictures above when the official nikonista was using the built in flash for everything. I look forward with interest to seeing his results.
I should really sell the AF280t and the AF240ft along with their wide and tele adapters.
Dangermouse
Posted 02/09/2010 - 21:41 Link
I'm now in a bit of a quandary:
I could buy a used Metz 45 CL-1 hammerhead flashgun, the trigger voltage is safe according to various sources and it comes with all the bits for £40
Alternatively I can get a bracket to mount my AF240Z in a similar position for £10
I don't use flash a huge amount, I already have the AF240Z and the cable to trigger it off-camera is in the post. However, I'm thinking that the bracket is £10 I could be putting towards the Metz unit. Thoughts?
gartmore
Posted 03/09/2010 - 10:42 Link
I would definitely go for the Metz - solid, powerful and reliable.
Dangermouse
Posted 03/09/2010 - 10:56 Link
Already have done - there's a Metz 45 CL-1 in the post. The first one I spotted had sold but I noticed an identical one for £36, which isn't bad even if I need to replace the nicads. They appear to be standard AAs so I just need to match the amp/hour rating.
Edited by Dangermouse: 03/09/2010 - 11:06
