Nissin 360TW with k100d
Some trigger voltages go as high as 200volts.
Just use caution and check the voltage first.
It has three output levels - full, half and quarter power, and a sensor so that it will, hopefully, expose correctly when used as fill flash in auto mode.
It's not a bad little flash, but my recommendation is to scour Ebay until you find a Pentax AF500-FTZ (if you want a manual flash). It's more powerful and more configurable. New ones go for 200 Euros, but I've picked up a couple in the last few months for a fraction of that.
Can anyone tell me if the Nissin 360TW will work with my k100d
as i've got the chance of one but don't want to try it on my camera incase I do it damage.
The flash was used with a Pentax MV previous to this so i'm assuming it is Pentax compatible.
Jim
