VIVITAR 6000 AF FLASH TTL AUTO FOCUS
Posted 30/10/2007 - 16:21
The K110D doesn't support TTL.
Only the *ist-D and *ist-Ds digital bodies supported TTL.
(All the DSLRs support P-TTL, but only the expensive digital flashes will support this.)
You can use:
* "A" mode on the flash
* "M" mode on the flash
(Check out some of the other threads here on flash & DSLRs).
e.g. https://www.pentaxuser.com/forum/viewtopic.php?t=4950 and the subheading "Use fully manual for controlled situations"
Since you are doing macro work, I would advise fully manual on both flash and body
Hope that helps!
You can use:
Hope that helps!
Posted 30/10/2007 - 16:29
Thanks for that.
Rochdale
