New K7 firmware! (v1.10.20.26)
And what did they improve this time?
EDIT : one thing I've noticed is that with auto-iso and flash, the camera restricts itself to reasonable sensitivities, whereas before (from memory) it had a tendency to ignore the flash and go to full iso if needed, leading to noisy flash picture (the Kx is still doing this, BTW).
I'll do a diff on the two files
But the K7 has always had a choice of ISO approach - Slow, Normal, and Fast.
I experienced this with my Kx this very Sunday : with a bounced Sigma 530, it choose to use 6400 iso nevertheless... Sure spares the batteries, but image was trashed right away... I had to use a fixed iso to solve the problem.
Could someone test this with the v1.10.00.25 firmware before updating?
Strange that they went from 1.10.00.25 to 1.10.20.26
It will depend on the software numbering format they use. Could be based on major.minor.build.revision or major.minor.revision.build or one of many others and the 20 may not be the twentieth but second version/attempt &c
Upgraded my K7.
Checked flash + ISO - definitely follows the ISO choice of "Slow", "Normal", and "Fast"
Doh! Should've checked before I upgraded to see if there was a real difference
Just did a diff. There are some subtle differences in the two files. Interesting that they both have the same date & time too!
Upgraded my K7.
Looks like the same July update (8/07/2010) to me. What am I missing?
I now find I have to use flash W/B to get good colors, but in the past I had to use AWB with flash to stop the colors from being washed out. (as detailed in the article on flash use in the final Pentax magazine) This is using the built in flash by the way.
A possible change
Also 1600 iso looks less noisy or maybe i was just lucky, peps with more experience would have a better idea.
Jim
This one is 1.10.20.26, MD5 is f6a4c771c0d4caf9e264f4ab0c6a9d4b...
