New K5, need help with noise reduction
fatspider
Posted 31/12/2011 - 14:14 Link
I now shoot in TAv mode, something I would never have done with the K10 or 20, both of which I rarely went over ISO400 with.
Juvenile Robin, K5, jpeg, ISO 2200, run through Neat Image using the profile available for the K5 and leaving it up to the software to do its own thing.
Yes you will get noise on the K5 at higher ISO but at least it can be dealt with.
My PPG link
My Flckr link
m42geo
Posted 31/12/2011 - 14:37 Link
I shoot images like thislinkfor living and I really don;t have the time to shoot RAW and PP each image. That is why I normally shoot jpg and do very little PP. I sometimes need to process 200-400 images a day so I have average about 2 -3 mins to retouch a photo which inculdes softening skins and so on.
Anyway I have given up shooting higher than iso400 with the k5 now since many of my client do want prints up to 20x30 and I need to ensure the noise level is near non exsitant.
it seems now I have to get the iso 100 images from k5 look as good as those I got from my k20D, I guess I must play with the setting.
Sprocketdog23
Posted 31/12/2011 - 15:12 Link
Have a go with the colour setting set to reversal film, and turn on highlight correction, & shadow correction to medium. In reversal film, use Ex sharpening, put it up to a higher setting. White balance for the shoot.
You should get some pretty punchy results.
'The best camera you ever have is the one in your hand'
Pentaxophile
Posted 31/12/2011 - 15:48 Link
I think perhaps a little streamlining of the workflow might be needed there, but that's probably a topic for another day!
As far as your concerns on ISO, looking at your (really nice) model shoot with flash, I can't see why you would want or need more than ISO 400 for this sort of work tbh. Check out the jpeg image samples below. You'll stuggle to recreate such identical shooting conditions for your own comparison. The camera for comparison is the K7 as the K20D review has been taken down, but it's the same sensor.
http://www.imaging-resource.com/PRODS/K5/K5PICS.HTM
http://www.imaging-resource.com/PRODS/K7/K7PICS.HTM
At ISO400, the K5 is already smoother than the K7 although both will print great at that size. As well as allowing a comparison between the bodies, the samples also show the effect of applying extra contrast, saturation, custom image settings, and the D-range settings.
Edited by Pentaxophile: 31/12/2011 - 15:48
fatspider
Posted 31/12/2011 - 16:09 Link
WOW1 that's like 12 hours a day spent processing if your business has that much turnaround surely you need an assistant, your gonna' burn yourself out carrying on like that!
My PPG link
My Flckr link
MarkTaylor
Posted 31/12/2011 - 18:33 Link
Decent RAW processing software (like Lightroom) allows you to set up presets and do batch processing. I.E. automatically apply the same noise reduction to each photo taken at the same ISO, same corrections to each photo taken with the same lens, and so forth. Basically everything that would normally take place in camera when creating a jpeg (and more, if you want).
Edited by MarkTaylor: 31/12/2011 - 18:34
Opethian
Posted 31/12/2011 - 21:43 Link
m42geo wrote:
ok I have just done a few more test. I think at high ISO say ISO 1600 or ISO 3200 there is no question that the K5 is alot better than k20D, however it is not good enough to make a 18X12 print. I always print at that sort of size and in this case looks like I have to keep my iso just as low as I used to shoot on the K20D under ISO400 is acceptable.
A little disappointed but that is life.
At least you got quite a lot for £600! Play to the strengths of the camera, and considering you're coming from a K20D, I would like to think that this "little disappointment" will soon go away.
I look forward to your photos sir!
cabstar
Posted 01/01/2012 - 04:30 Link
During a festival I can shoot 1500 images a day the majority at ISO 800 plus over a quarter will be ISO 1600 and above.
To process that many I have lightroom setup as others have mentioned to do noise reduction & sharpening depending on ISO & camera body on import. Like you I don't have the time to do much post but at least I have the computer do as much automation as possible, then maybe 90 seconds per image post...
During festival time my day is roughly spent 30 / 70 shooting / processing & uploading to the wires.
Concert photography
