Completely Dejected (auto focus K5)
Posted 26/12/2011 - 18:50
k-5 is known for this issue, that what the latest firmware update is mainly for....
Posted 26/12/2011 - 18:54
Is that a firmware that is yet to be released or one that has already been released? I am on 1.03
Posted 26/12/2011 - 18:56
Posted 26/12/2011 - 18:57
I am already on 1.03 and therefore it hasn't cured the problem. Googling it finds loads of people with the same issue. Proper cheesed off right now.
Posted 26/12/2011 - 18:58
are you using auto 5 point setting or 11 point setting(auto af),
try both see if this helps,or try liveview.
Posted 26/12/2011 - 19:03
Possibly a white balance problem?
i don't think auto wb can guess every setting.
Posted 26/12/2011 - 19:04 - Helpful Comment
It's a known issue with the K-5 and one that hasn't been completely corrected. This makes for an interesting read:
http://www.falklumo.com/lumolabs/articles/k5focus/index.html
John
John
Posted 26/12/2011 - 19:06
I'm wondering if there is a clue in your mention of tungsten light. I would reset factory defaults and try again using daylight. If you have correct focus in daylight then any problem may be restricted to extremely dull and coloured light, such as tungsten.
It's more usual to be taking photos in brighter light. Any errors can be corrected using QuickShift. In any event depth of field will cover most small errors.
Otherwise, if there's a real fault then returning under warranty seems to be the best option.
Posted 26/12/2011 - 19:09
I always use my HTC desire for photographing newspapers. Either that or I scan them before using them to light the fire.
Lurking is shirking.!
Posted 26/12/2011 - 19:10
Could you put some of your images on here moght help..
Posted 26/12/2011 - 19:24
John
Haven't got time to read all that now but I read the "Conclusion" and it pretty much says it all.
John
Posted 26/12/2011 - 20:48
johnwhit wrote:
John
I found using the kr with af360 flash the preflash focus assist solves the problem, and though I've not tested this, I think the ftz flash unit set to spotbeam never seems to miss focus...Daydreamjay wrote:
Sorry to be the bearer of bad news but I'm sure you could find a work around with some additional lighting.Haven't got time to read all that now but I read the "Conclusion" and it pretty much says it all.
John
not experienced any ff issues using video lights either..
some one with the time or inclination could thouroughly test this.... but try popping up your flash to prefocus, then dial down your flash exposure so it doesn't over power the ambient light... or pop the flash down before shooting after focussing..
I've spent the last 4 hours with the camera on a tripod and photographing the same sheet of newspaper over and over again. My K5 tends to front focus on all my lenses apart from the SMC FA 1.4 50mm. I fine tuned the focus so that it was focusing correctly but when I apply a brighter light source to the subject rather than the tungsten it now back focuses.
I'm really peed off about it and feel like selling up and moving to Canon.
How can I get round a problem that changes under different light intensities?
