Need quick help on a lens that's on Ebay
http://www.pentaxforums.com/userreviews/Tamron-SP-MF-90mm-F2.8-MACRO-F1-72B-for-...
John
I can't access Ebay from work but I believe this model will do 1:1 without the extension tube, if the mount is included it will work with your K-7 straight off providing the mount is OK. Some user comments here:
John
He says it comes with ' it comes with a Pentax P/Ka adapter'. Is this the same as the mount you mention?
Cheers,
pa
Tamron 72B SP 90MM F2.8 MACRO LENS ADAPTALL FIT pentax is for sale on ebay, auction ending very soon so if anyone could answer my questions I'd appreciate it.
Item number: 280702966252
http://cgi.ebay.ie/280702966252?ru=http%3A%2F%2Fshop.ebay.ie%3A80%2F%3F_from%3DR...
1. Is this a 1:1 macro lens?
2. Will it fit onto a Pentax K-7 or do I need to buy a seperate adapter?
3. Would you recommend this lens? My budget for a macro lens is €150 max. It'd be used for trying macro out, a bit of everything (mainly objects, not inscets). Ideally I'd like it for portraits too but don't think I'd find one within my budget.
These are the details the seller put up:
This is the 72B version, it comes with a Pentax P/Ka adapter but you can obtain other adaptall mounts to fit it to your camera. The lens has been well used & the exterior of the lens shows plenty of signs of wear, but it still works fine. Aperture works fully, focus is smooth & the optics are in very good condition. comes with caps
Thanks in advance for the quick answer,
Patrick.
Colors are the lack of darkness
You find more of my pictures here: https://pentaxphotogallery.com/artists/axelluther or on my web page: www.axel-luther.com
Oh well....
Then we end up bidding aginst each other...potentially.
And no, I wasn't bidding....
Agree on the mixed blessing though!
Just like the Lottery the Numbers always look so obvious
the day after!
Patrick.
Pa
