MX Flash Problem
Landy Mann
Posted 31/03/2008 - 11:05 Link
Hi my brother has a MX the hot shoe doesn't work nor does the bottem synk lead hole however i have got it working on the top one we are novices at camera repair so does any one have any ideas?
Thanks David
Miranda MS-3 35mm
Pentax *istD
Pentax MX 35mm
Richoh KR-10M 35mm
50mm SMC ASHAI PK
28-70mm Miranda PK
18-55mm Pentax DA
28-70mm CPC AUTO ZOOM PKA
80-200mm Hanimex PK
135mm Panagor PMC AUTO TELE PK
Too many flashes to count!
Mac
Posted 31/03/2008 - 12:56 Link
David,
If the MX is like most of the other Pentax bodies, the lower PC terminal is correct for electronic flash. (Marked "X"?) I assume your flash has such a cable? If so, it is usable.
It would help us if you could tell us the make and model of the flash in question. Very often the problem is with the flash's hot shoe terminal. Is there another flash you can try?
Good luck
l
Mac from Montreal
Peter Elgar
Posted 08/04/2008 - 20:45 Link
Some years ago my MX packed up flashing on a job and I had to use the 'Open Flash' method (luckily it was in a dark school passage way )- it turned out I had taken so many flash photos the contacts were burned out !
