Mount cutters
tyronet2000
Posted 21/10/2011 - 18:22 Link
Any recommendations on mount cutters, I have seen some at high (for me) prices but also around the £30 mark
Stan
RAB
Posted 21/10/2011 - 18:47 Link
I use one of these.
It's a wee bit above your price bracket but is a quality piece of kit. I've used a cheaper one in the past but it doesn't approach the Logan system.
"He's not the Messiah, ..."
Edited by RAB: 21/10/2011 - 18:47
grahamwalton
Posted 21/10/2011 - 19:12 Link
I have and would recommend a Frameco Matmaster, which are available from Lion Picture Framing in Birmingham. It was expensive but is of all metal construction and will not warp. If you have a look at the Lion web site, they have many other options in mount cutters.
A good straight edge and a bevel cutter, is obviously the cheapest solution.
I must admit for most of my print mounts, I stick the photo on the surface of a mounting board using 3Ms Photo Mount adhesive, in the red tin. In my experience, other adhesives do not perform as well as 3Ms Photo Mount in the red tin.
Friendly Regards
Graham
CoDa
Posted 21/10/2011 - 21:28 Link
Have a read of this
Colin
Edmund Burke (1729 – 1797)
gartmore
Posted 24/10/2011 - 11:21 Link
RAB wrote:
I use one of these.
Me too!
You should practise and take a lot of care. Remember, measure twice cut once!
DOIK
Posted 24/10/2011 - 11:41 Link
gartmore wrote:
RAB wrote:
I use one of these.
Me too!
Another Logan user here. I use a sheet of crushed polystyrene like the stuff used with laminate flooring under the mount, the blade just glides through the cut.
John
tyronet2000
Posted 24/10/2011 - 12:53 Link
Oh, I always do it the other way, no wonder nothing fits first time
I think my best option is to stick to standard sizes. Never was much good at DIY.
Stan
Stan
