Metz 58 as slave - flashing, but not when shutter open
Darkmunk
Posted 28/01/2008 - 12:07 Link
tried to use the Metz on the beach in the dark as a slave triggered by the on board flash set to 'controller'. I could see the Metz going off with my eye but the actual photo (which included the Metz in the image - fish eye lens) showed no flash and the picture was dark. if I set the on board to 'master' the scene is lit by the on board flash but the Metz is still (apparently) not syncing with the shutter.
the shutter was 1/20th
I gave up and went home...
just a thought, I think the Metz was set to ttl as well as slave (is that possible?) so the pre-flash communication might have concluded (because it could see the Metz) that the scene was really bright and not fired the Metz???
hefty1
Posted 28/01/2008 - 12:56 Link
If the Metz was set to TTL instead of P-TTL then it was being triggered by the pre-flash from the camera. If you set it to P-TTL it'll ignore the pre-flash and strobe in sync with the main flash as it should. I'm sure it'll be fine.
Joining the Q
