Metz 48 af-1 DOES NOT FIRE
Posted 16/10/2010 - 23:29
Hi Gareth,
I haven't updated the firmware, like I said, it worked 2 days ago, that was the last time I used the flash. It does not fire when I press the test button also... I could update the firmware, but not sure that will fix the problem, only say that because it worked fine the last time I used it during the week! Any other suggestions? lol
Thanks,
Jay
Thanks,
Jay
Posted 16/10/2010 - 23:34 - Helpful Comment
This was duplicated so the other thread has been removed. Please only post once in one place to avoid confusion.
Posted 16/10/2010 - 23:40
Damn, I hope it isn't broken... but would be just my kind of luck
Thanks for the help Gareth, appreciate it.
Oh, sorry John, won't post more than once next time.
Posted 17/10/2010 - 00:07
A daft question, but have you tried replacing the batteries?
Also, try taking out the batteries and leaving it for a few hours to fully discharge then reinsert a fresh set and try it again.
When you first turn it on can you hear the high pitch whine as it is powering up the capaciter (hold it to your ear), Have you tried firing it wirelessly ??
Put a fresh set of batteries in it and try again.
Camera:|K-7|
Posted 17/10/2010 - 00:29
When I turn it on, the flash zooms forward then backward like normal. The ready light is green, and nothing happens when i press it. I have rechargeable batteries which aren't anywhere near low on power, and when I do press the ready test button, it sometimes displays all the icons on the lcd display... and I mean everything! all the mode and settings icons appear at once. I don't think this is broken when doing it, but I could be wrong.
Posted 17/10/2010 - 12:22
You can update your flash, maybe that might help
http://www.metz.de/en/photo-electronics/firmware-download-flash-units/mecablitz-...
Posted 18/10/2010 - 10:32
Hey Anvh,
I done the update, but still, no change... it just wont flash. Do you know if there is any function that i may have possibly pressed, which may not make the flash go off, like a safety mode / function?
Jay
Jay
Posted 18/10/2010 - 12:26
Hey Gareth,
Nah, it makes the high pitch noise... so it is a crazy situation. Do you know how to take off the from plastic covering the bulb?
ps.. cool flickr by the way. heres mine www.flickr.com/photos/blackwatch_photography
Jay
Jay
Posted 18/10/2010 - 12:34
One word of caution - flashguns use high voltage and can give you a very nasty shock. Please be careful if you are going to take it apart.
Posted 18/10/2010 - 12:39
Of course. I would take the batteries out, and just want to look at the bulb to see if it has blown or not. Thanks
Posted 18/10/2010 - 12:43
There's more to it than taking the batteries out. You have to make sure the capacitor is discharged.
Posted 18/10/2010 - 12:45
If you do that the capacitors will still be charged. Take the batteries out and leave it for several hours before attempting to dismantle it.
As well as giving you a shock it could blow all the circuits!
Posted 18/10/2010 - 14:16
Make sure you allow enough time for the capacitor to discharge as well, or you might get a mighty kick anyway!
Thanks in advance.
