Metz 36AF4 with M lenses
kris713
Posted 17/09/2011 - 19:17 Link
I'm using the above flash which I bought off SRS ebay shop recently. A very nice flash till you're using an A or F lens. For some reason the flash completely refuses to fire when using a non A manual lens (in this case a Helios 44K). Any advice on how to make this work with a Helios 44K?
Jonathan-Mac
Posted 18/09/2011 - 18:50 Link
As the flash & lenses are all manual, you will need to put the camera into M mode & set the shutter speed to 1/160 (if camera set to 1/3 stops) or 1/180 (if set to 1/2 stops). Thatīs the sync speed for Pentax flashes. Below that speed Iīm not sure what the results will be like, it may work, but above that speed the flash simply wonīt fire.
sterretje
Posted 23/09/2011 - 18:24 Link
The effect of a slower speed will be that more of the available light will be included in the image.
kris713
Posted 25/09/2011 - 18:03 Link
Apparently 36AF4 does not work with non A manual lenses. It does not fire when using a non A manual lens, whatever the shutter speed.
