meike mk rc7 trigger/remote
moose
Posted 18/08/2011 - 23:42 Link
Just wondering if anyone has used meike triggers?
link
My main use would be as a long distance remote, but also would like to play strobist.It would seem that they should work with pentax.
The price sounds attractive and AAA batteries for both trigger and receiver adds extra appeal.
Would be used with K10D and old pentax flashes af280t & 200t
selectcase
Posted 19/08/2011 - 08:23 Link
it should work fine but remember that your flashes dont have a pc sync connector on them so you may need to get a hot shoe adaptor with a pc socket on it
i use the cheap cactus triggers and they work well so i see not reason why these should not and it you get no success you still have a remote
K7D DA 18-55 mk11WR|50-200 wr|DA16-45|Tamron SP90|lots of manual pentax glass
moose
Posted 20/08/2011 - 21:36 Link
thanks,but why would the lack of pc sync connector be a problem? Surely the receiver fires the flash through its hot shoe or am I missing something?
selectcase
Posted 21/08/2011 - 09:54 Link
yes it does but looking at the picture if you connect the remote to the hot shoe of the flash how do you then connect it to a stand? it may be on the other side and not visible? if you cant then you would use the hot shoe to mount the flash to the stand with a small pc cable from the hot shoe pc socket to the remote - having said all this i cant see a pc socket on the remote either its hard to tell. For a remote is a good price and you will find them useful
here is a link to a trigger which might explain better as you can see the reciever has a flash mount on the top then a bracket to attach it to the stand
link
moose
Posted 21/08/2011 - 12:25 Link
I understand where you are coming from now. I have tracked down some other images/info and there is a 'cold shoe?' and a 1/4" threaded mount on the underside.
Do appreciate you raising this, as I would not have thought to check.
selectcase
Posted 21/08/2011 - 12:32 Link
you shold be fine then
Posted 21/08/2011 - 17:26 Link
There are some radio triggers that will only fire once on Pentax
(It's to do with the better protected electronics on the Pentax camera hotshoe that 'lock' depending on the trigger electronics)
Others will only sync at very slow shutter speeds... so it's best to check.
Edited by MattMatic: 21/08/2011 - 17:26
Anvh
Posted 21/08/2011 - 17:37 Link
The cactus v5 work can work as ta remote as well and they do work like they should but they cost more though...
Stefan
K10D, K5
AF-540FGZ
moose
Posted 27/08/2011 - 10:42 Link
Reviews for these with pentax are scant, so can't find out if they will only fire once or check reported sync speeds.
Hadn't realised the cactus v5 also worked as a remote.
At the end of the day I guess they are worth a punt, at under £20 it is hardly high risk.
cheers for the input
moose
Posted 22/09/2011 - 17:50 Link
For those interested, an update.
I have these triggers now and found the following.
Work fine as a remote have not checked full range but do work though walls and have tested to 30m or so with no problems.
Flash (af200T) fires pretty consistently, but only first fire syncs properly with any shutter speed over 1/30th. However have found that by doing a half press on the transmitter each time before using the shutter button will allow sync up to 1/180th nearly all the time.
I imagine this is something to do with the problem Matt mentioned. I am sure the transmitter could be hacked, but I am just using a bit of blue tack to hold the button half pressed for now.
