Media Storage Drive
You will need to let us know what equipment you have so that we can advise the best option. Normally you would connect your hard drive to a computer and insert your media card into the slot on your computer. You can then copy directly to your hard drive.
Cedric
Try Googling Image tank and see what others come up. All Vosonics have been discontinued it seems. Overtaken by netbooks and clouds. Nexto still make one I believe.
I think there is something wrong with your laptop if it is shutting down when copying files - it should not do this. I'm not sure how you can copy from a SD card to just a hard drive - you need a computer of some sort, or a media tablet (Apple ipad or any make of Andorid powered tablet).
Better still, get someone to sort out your laptop - it really is the easiest way to copy your files. Are you anywhere near to Sheffield? I would be happy to help you.
Mine has a rechargable lithium battery and also a small leather pack which takes 4 AA's as a backup.
Maybe if they are not made anymore as Gwyn says then maybe you can find one on ebay. they all take mutiple cards for down loading and are all of a reasonabley pocketable size and have different capacities. (30, 50, 80, 120, Gb.) etc.
Hi. Gwyn. Mine is a X's Drive Super (VP6210) What's yours?
I got mine to take to Kenya on safari in Sept. 2005.
CHEERS Vic.
Will
Concert photography
As for the laptop, well I found this model was very fickle with temperature problems. It just does not like handling 4 gbyte of files from my K5. I use it sat on a cooling fan. I suppose the ideal thing would be to load the files from cards to the PC but that`s two floors up but probably the answer. Would have been nice to store all the pix from say a week away on one portable device as a backup to the cards.
Many thanks though.
I use a netbook and a photobank. Photobank great for simple backup in the field; netbook great for making sure you've got what you wanted before leaving where ever you are and it's too late to return
East Suffolk
many thanks
