Manual Exposure??
Posted 30/06/2009 - 11:55
I suspect you zoomed for various exposures, and the aperture will change as you zoom unless the lens is a constant aperture design.
Posted 30/06/2009 - 12:52
Are you sure you are reading the EXIF correctly? Depending on the software it can be wrong.
Posted 30/06/2009 - 13:53
That doesn't sound right. There is a program item which you can turn on which will auto compensate exposure, but I dont think it applies in manual exposure.
By the way, if you are setting your exposure in Manual mode with your eye to the viewfinder, you dont then need to use the eyepiece cover.
Posted 14/07/2009 - 15:56
I was using the 18-55 kit lens. Everything was set to manual and the zoom was not used (I was doing some multiple exposure shots), and I used the eyepiece cover, remembering the advice I had received years ago with reference to my LX body and its metering system.
Hmmm, yes it could be the EXIF which was not read properly. I was using PS Elements 6. Does anyone else have experience of this phenomenon with PSE 6?
Posted 14/07/2009 - 19:19
I have had this experience some years ago, studio set up and everything on manual. It was only when looking at he PSE 'contact sheet' that I could see an exposure variance. No idea why I'm afraid.
