M42 adapter for the K5
Posted 07/01/2011 - 13:15
Sounds like you need to take your K-5 back to the Dealer.
Posted 07/01/2011 - 13:16
Are you attaching it by the correct method?
Screw it onto the lens before attaching to the camera, remove by unscrewing lens then unclip and remove the adapter.
Posted 07/01/2011 - 13:17
If there was a problem with the camera then lenses wouldn't fit either.
Posted 07/01/2011 - 13:24
I got one of those and my one fits perfect. Use 'gartmore's' advise on how to use the adaptor.
I don't have any problem with it whatsoever.
Kind regards
SmutjeUK
It's nice to be nice!
SmutjeUK
Posted 07/01/2011 - 13:33
gartmore wrote:
So that's why they keep falling off and going Thump!!!
If there was a problem with the camera then lenses wouldn't fit either.Sounds like you need to take your K-5 back to the Dealer.
Posted 07/01/2011 - 13:47
No, I've been attaching it to the body then screwing the lens into it.Are you attaching it by the correct method?
I'll try your method and see how that goes, thanks.
Either that or I have a fake. I did buy it from eBay but it looks like the real deal and it was from a reputable seller.
I just don't understand why it fits the ME Super perfectly and not the K5 (and this is the 2nd K5 I've had so there's definitely nothing wrong with it).
Posted 07/01/2011 - 14:33
If it came off ebay there's a good chance that it's a fake
It should be in a green plastic pouch with a Pentax leaflet and
have a sticker that says 30120 Mount Adapter K
I don't know where I've put mine to get the lettering off the adapter.
If you look through Classified there should be photos of ones already
sold.
If it has K/M on it it's a fake. It should have Pentax Japan on it.
sold.
Posted 07/01/2011 - 14:51
There may be one other possibility. There should be a spring like plate just next to the red spot. It is screwed in to the adapter. Make sure that this is there and that there is some 'spring' in it as without it you may get the symptoms you describe here.
Don't know why it works on your ME Super but it may be that the arrest mechanism on the camera has changed somewhat so that it will sit secure on the ME but not on the K-5 (quite a few years between them and it may just need some slight adjustment for the AF and all the other electric contacts that may influence the setting).
Hope that helps a bit.
Kind regards
SmutjeUK
SmutjeUK
Posted 07/01/2011 - 14:53
It was second hand so just arrived in a jiffy bag, but it looks identical to the official one and says Pentax Japan on it.
Exactly the same as this photo:
http://www.srsmicrosystems.co.uk/156/Pentax-Mount-Adapter-K.html
It was purchased from someone who was selling a load of old 35mm kit, so maybe it's a slightly different older version. Weird.
Posted 07/01/2011 - 14:55
Thanks, I'll check that when I get home. The spring/plate is definitely there but I might try bending it out slightly.
Posted 07/01/2011 - 14:56
Its the same as I got and you actually can see the spring plate on the left to the 'P' where the cut out for the bayonet is.
If the spring is missing or no longer working I am sure you get the problem you describe.
Kind regards
SmutjeUK
SmutjeUK
Posted 07/01/2011 - 14:58
Isomi wrote:
Be very careful with that as if you bend it too far you may get problems of releasing the adapter from the camera as the spring plate may block then the mechanism!
Thanks, I'll check that when I get home. The spring/plate is definitely there but I might try bending it out slightly.There may be one other possibility. There should be a spring like plate just next to the red spot. It is screwed in to the adapter. Make sure that this is there and that there is some 'spring' in it as without it you may get the symptoms you describe here.
Kind regards
SmutjeUK
SmutjeUK
Posted 07/01/2011 - 14:59
I've got an old one from the 70's that came in a Pentax box.
The lettering was a bit different, but the the manufacture is
identical and made to very tight tolerances. The copies are not
to the same tolerances.
Posted 07/01/2011 - 15:03
Noted!
East London
I have the official Pentax M42 adapter which fits my ME Super perfectly, but for some reason it's incredibly loose on my K5. It appears to be smaller than the lens mount and doesn't lock in place either.
Can anyone recommend a third party adapter for the K5/K7 that fits properly?
Cheers,
Don
