M42 + adaptor or SMC
Posted 08/12/2008 - 15:59
You could happily use your existing lenses on the ME Super. The adapter effectively turns it into a screw thread camera and you can change lenses in the usual way. Apart from using stop-down metering there aren't any disadvantages really. The lenses you have are already very fine ones.
If buying lenses though you might as well have the SMC Pentax or SMC Pentax-M ones as they will be slightly faster to use and also there will be more adventurous designs available, such as the 50mm f1.2 and the various zooms.
Posted 08/12/2008 - 20:20
Is the 'Pentax K Mount Adapter' in the shop here the one I'm after? if so says up to 28 days, how close to the mark is that, was hoping before xmas? Not finding anything genuine Pentax on the bay.
S Raff
Posted 08/12/2008 - 21:48
Pentax Adapter K should be available easily enough - try SRS
North Devon
Okay may of gone on there a little but hope you get the jist of what I mean and your thoughts are appreciated.
