Lens cleaning paper - thoughts?
johnwhit
Posted 10/01/2011 - 20:48 Link
I used lens tissues for years never had any problems, the best thing is you start with a nice fresh one every time, microfibre cloths become soiled over time, although most are washable AFAIK.
John
PPG link
In LBA hiatus.
sazanovich
Posted 10/01/2011 - 20:58 Link
davex wrote:
Strongly recommend these
The size of face flannels, well worth 2 quid.
Davex.
Looks like kitchen towel to me :O
I would probably be scared ti try these... If they say they use it for car cleaning - I would not try it on MY optics
I got one from jessops some time ago wich looks more appropriate, but use it mainly for camera LCD cleaning; To clean optics, I use optics cleaning tissues http://www.thorlabs.com/thorProduct.cfm?partNumber=MC-5 with a drop of pure (99.99%) ethanol, and taking care not to touch lens mount not to spread dust from the mount edge onto the lens. Mostly just touch the lens with the tissue corner (wet in ethanol) and gently drag-lift it away.
Algernon
Posted 10/01/2011 - 21:15 Link
In their lens manuals Kiron say that dry tissue will scratch
the lens coatings and it should always be used moistened with
lens cleaner.
For a final wipe Selvit cloths are about the best for removing
bits left behind by microfibre cloths etc. I find them too soft
to actually clean off anything worse than finger prints.
Samsung supply a very good soft blue cloth with their monitors.
Persil washing powder is very good. I find I have two children
and it brings them up lovely and clean
Algernon
Posted 10/01/2011 - 21:18 Link
Mike-P wrote:
I use silver Rizla papers.
There is someone on one of the forums that uses "Scotch Magic Tape" to clean his sensor
Blythman
Posted 10/01/2011 - 21:27 Link
What's wrong with newspaper and vinegar Mike?
Alan
Posted 10/01/2011 - 21:30 Link
I like that idea, especially if it makes the Whites Whiter.......
Some Cameras
Smeggypants
Posted 10/01/2011 - 22:20 Link
Breath condensation and fresh loo roll. works a treat
fatspider
Posted 10/01/2011 - 23:55 Link
Forget the lens tissues, just buy DA* lenses with Pentax's "Muck Repelant Technology"
Seriously, I get tired of cleaning lenses but both my DA* lenses are now a couple of years old and apart from the odd wipe with a microfibre cloth to remove surface dust they have NEVER needed cleaning, my other lenses however need a regular hose down
My PPG link
My Flckr link
hefty1
Posted 11/01/2011 - 00:14 Link
Mike-P wrote:
LINK
Thought I was kidding eh.
And there was me thinking I was the only one doing it! My lenses get treated to green Zig-Zag papers though - only the best will do...
Joining the Q
gartmore
Posted 11/01/2011 - 08:08 Link
The correct way to use the tissues is to roll them up and tear them in half so that you have a sort of soft fibrous end and wipe in a circular motion. Personally I have never found them to be very effective.
I use Selvyt cloths which can be chucked in the washing machine, but not the tumble dryer, and last for years.
gartmore
Posted 11/01/2011 - 18:12 Link
cardiff_gareth wrote:
I always use an optical microfibre cleaning cloth, I currently have 2, one bought from Jessops, the other was free with AP, even has my photographic rights on it !
You can even buy them from most glasses shops ie specsavers etc
Ah, but if you have grit and work the tissue in a circular motion you can strach circles into the front element. Always go from side to side to any grit is pushed to the edges
Davex.
Hmm, seller says they are for lense not lenses
I wouldn't be using any kind of cloth if there were foreign objects on the surface
hefty1
Posted 11/01/2011 - 18:15 Link
+1
I use a little blower brush to remove small particles before wiping.
Joining the Q
Algernon
Posted 11/01/2011 - 19:05 Link
Leica used to recommend cleaning radially from the centre outwards.
3M make a decent microfibre lens cloth for about £1 hard to
find though
EDIT: Well I'm blowed.... someone just posted a link to
them in Leads to Deals..... 12 for £5.10 + £2.50 packing
only 63p each..... BUY NOW!
Edited by Algernon: 11/01/2011 - 19:25
ManixZero
Posted 11/01/2011 - 19:38 - Helpful Comment Link
In my work I have regularly clean the very exotic optics optics of a range extremely expensive excimer lasers. To improve efficiency.
The method recommended by the manufacturer to maintain maximum transmission is to take a folded (to a width of 1cm approx) lens tissue moistened with with alcohol (methanol) and firstly wipe the entire optic, vertically, then horizontally, repeated 5 times, blowing the optic with nitrogen between each series of wipes. (canned air + lens fluid will do at home)
The improvement in transmission is actually measurable in terms of increased fluence and the life of the optics is increased too.
I use a similar technique on my camera optics only paying more attention to the periphery of the lens.
I use my Silver Slims for "Other" purposes! In fact I may see what I can conjure up before the footy starts
Cheerz
MZ (Come on you blues!)
K5, K7, Nikon FA.
AF Lenses: DA15mm Ltd, DA21mm Limited, DA35mmAL, DA50mm f1.8, DA18-55mmWR, FA28-70mm f4AL, DA50-200mmWR,Tamron SP70-200mm f2.8, AF70-300mm LD Di, SP10-24mm, SP90mm Macro.
MF Lenses: SMC-A 50mm, Adaptall 24mm(CW-24), 135mm(03B), 35-70mm(17A) 80-210mm(03A), Micro-Nikkor55mm, Soligor I-S 200mm f2.8 AIS
My Flickr - link
My Photobucket - link
Edited by ManixZero: 11/01/2011 - 19:39
Algernon
Posted 11/01/2011 - 20:58 Link
Eddie Houston's selling this cleaner on ebay looks
interesting.
I've never seen a cleaner that removes everything off older
lenses.
