Kr Faulty Edial
Posted 19/04/2013 - 16:42
Well known problem try squirting some electric contact cleaner into the dial slot and move the dial around a bit seems to work for a lot of
folks. Some even use wd 40. I think the problem is to much grease on the edial.Have a look on the other forum there is quite a bit about it.
Posted 20/04/2013 - 09:51
Morning Geordie is this what you refer to on the other site or are you saying just run a little lubricant cleaner around the dial slot on top of the camera ?.
http://www.pentaxforums.com/forums/pentax-k-r/145847-k-r-e-dial-repair.html
Posted 21/04/2013 - 12:53
Here
http://www.pentaxforums.com/forums/pentax-k-r/219676-k-r-problem.html
http://www.pentaxforums.com/forums/pentax-k-r/193888-fixing-pentax-kr-edial-issu...
http://www.pentaxforums.com/forums/pentax-k-r/189303-k-r-e-dial.html
done mine with contact cleaner 6 months ago and it's fine since
Posted 21/04/2013 - 15:15
Thanks Geordie will have a stab at it.
Ian
Ian
Posted 21/04/2013 - 17:42
Well just found a tin of wd40 and gave it a go and pleased to say alls well again. Thank you Geordie for the tip this has saved me quite a bit of money in repairs.
Ian
Ian
Regards Ian
