K5 viewfinder size
Posted 27/11/2010 - 15:50
It looked fine to me, very bright and clear and the size I would expect.
Posted 27/11/2010 - 15:58
From memory (I sold my k-10 a couple of years ago) I would say that the viewfinders are the same size. The K-10 gave 95% coverage while the K-5 gives 100%.
Archie
Posted 27/11/2010 - 16:02
The viewfinder is bright, clear and offers an effective 100% frame coverage - so what you see is what you end up with on the photo.
The K10D offers only 95% frame coverage.
Posted 27/11/2010 - 16:14
thanks for the advice, I was only concerned that the size/magnification of the finder on the K5 was smaller than my K10.
rick
rick
Posted 27/11/2010 - 21:32
I bought the viewfinder magnifier for my K-5, and it has definately improved the viewfinder (which I found a little darker than Canon/Nikon competition).
Posted 28/11/2010 - 17:45
The K7/K5 might have 100% coverage, but do not forget that is only part of the story, the more important part is the magnification of the viewfinder and I believe I am correct in saying that although the K7/K5 has better coverage, they have lower magnification. I think the K10D/K20D & K7/K5 to all intents and purposes have virtually identical sized viewfinders.
Posted 28/11/2010 - 18:44
The K10D/K20D has .95x magnification, the K-7/K-5 0.92x.
Nonetheless my experience is that the K-5 viewfinder is superior to the K20D.
Posted 28/11/2010 - 20:46
does the Pentax O-ME53 fit the K5?
Barrie - Too Old To Die Young
Posted 28/11/2010 - 20:48
You can get the M-OE53 from most Pentax Pro stockists like SRS in the UK. I use one on my K-5 to help handle some older MF lenses. Be aware that there is a tiny bit of vignetting in the extreme corners, I find it is the upper left and upper right but it may be different for others. I barely notice it now.
http://www.srsmicrosystems.co.uk/456/Pentax-O-ME53-Magnifying-Eyecup.html
I believe the O-ME53 fits all Pentax Dslrs, it is really easy to fit, pull the eyecup up and off and replace with the magnified version, less than 2 min job.
Posted 28/11/2010 - 21:16
There are some unoriginal viewfinders with magnification for Pentax under different names as well. KPS (I believe) and Tenpa are said to be good and I think some from this forum uses them. I haven't tried myself.
Hi. My name is Joel and I'm a travelholic.
Stolen kit: Pentax K7 #3428965 and Pentax FA 43mm #0028350
Posted 29/11/2010 - 10:28
Got one from Tim last week - very good even for glass wearers
Posted 29/11/2010 - 11:04
Pentax have stuck with the same size viewfinder fitting since the M series cameras and so all their accessories since then will fit all their dSLRs.
The only exception (I think) is the K1000 which began manufacture before the M series but carried on much later. It, therefore, has the older Spotmatic/K series fitting.
K.
K.
20 years
hampshire
can anyone comfirm this?
regards
Rick
