K5 II Preview / Playback not working
Posted 19/10/2014 - 12:47
Hi Don
I doubt this would be a battery problem and as long as the images are on the SD card - not an SD card issue either.
There is no menu function to switch off playback (as far as I know) so sounds like you will need to contact SRS. It is not the first timer I have read of this happening.
Carl
Carl
Posted 19/10/2014 - 15:42
Carl,
Many thanks for the response, it is good to know I am not the first to experience this problem. Just 30 mins ago, I switched on the camera and all was fine and I could review my images on the card and then for no apparent reason the playback button refused to work - seems I will be contacting SRS for warranty advice.
Don
https://www.flickr.com/photos/108420945@N06/]
Hoping to get some advice re an intermittent fault on my K5II which for some reason on occasion refuses to show images when the playback button is pressed. I have alternatively tried removing and replacing the battery which did resolve the problem once but has so far failed to work again. I have also tried different SD cards but the fault persists. The images are definitely on the card as I can view them on my laptop but the K5II refuses to display them on the LCD. I have also tried a factory reset to no avail.
The camera is thankfully still under warranty with SRS but I was hoping someone on the forum might have a solution or at least knowledge of this fault.
To clarify, once having taken a photo, the image is shown on the LCD screen but after the preview time of 5 seconds I can no longer access the image.
Many thanks for your time.
