K30 Remote cable release thingy ?
Posted 05/09/2013 - 17:03
I feel daft replying to my own post BUT
I've tried in all the logical places to check this
Information gleaned from Pentax UK Site
the Remote F was designed for the *ist D, Optio 555, 550, 450, S4, S, 430RS, 430, 330RS, 330
I KNOW the CS 205 [ the wired one] works on the K7 and K5 and again from their website Designed for the MZ-6, *ist Date, *ist D, *istDS, *istDL & *istDL2
In sheer disgust I emailed SRS and within minutes got a response from Doug
Yes the CS205 will work with the K-30.
Now THAT is service
let the education continue
Posted 05/09/2013 - 21:02
grrrrrrrh
Posted 05/09/2013 - 21:56
make your own.
2.5mm stereo jack plug. twin core cable - length to suit. Suitable switch
Jack sleeve = 0v
Jack Ring = half press
Jack tip = shutter release.
You don't need to make the 'half press' circuit to trigger the shutter. At least not on the K10D, K20D and K-5
Jack sleeve = 0v
Posted 05/09/2013 - 22:06
I have an old (ahem!) Canon one. It was considerably cheaper than the Pentax equivalent, and has worked on every Pentax camera I have had from my Ds on.
Posted 05/09/2013 - 22:21
Now that comment cheers me up Thanks Gwyn
Mr Smeggy - me no that handy making things My husband would have had a go for me - but me ????
Posted 06/09/2013 - 08:35
I bought a £5 PowerPlanet compatible CS-205 wired remote from Amazon UK. There was no mention of K-30 compatibility but it works fine.
Posted 06/09/2013 - 09:01
Ditto me too. I bought a £5 PowerPlanet compatible CS-205 wired remote from Amazon UK. There was no mention of K-30 compatibility but it works fine.
Also have the official Pentax IR remote that came with my K10D but prefer a wired remote.
Posted 06/09/2013 - 09:09
I also have the IR Remote but for simplicity at times was looking for a wired one since the K30 does have the terminal for one.
I've also taken the plunge now and ordered up the PowerPlanet one
Wonder why Pentax has not updated the list of compatible cameras for the CS-205 - it just doesn't make sense not to
Posted 06/09/2013 - 15:00
The remote F will work with the K30 as well. I have one and I used it from the old Pentax EL2000/3000, K10D/K20D, K7/K5 and now the K30
Posted 11/09/2013 - 22:03
I have a cheap cable release from E-bay. Works very well. I also have the IR remote by Trust. Also works well
K30, K-x, *ist DL. Pentax 60-250 F4, Sigma 18-125 & 70-300
Glasgow
The manual shows a socket for cable release - but tells you how to use the Infra red remote.
I would appreciate being able to use the wired gadget as I want to use it where I can't actually have the IR remote in front of the camera .
