K3 cancel AF problem ?
Posted 04/02/2014 - 17:54
I've just had this reply from the Pentax Ricoh Imaging Technical Support team.
Dear Mr. Miller,
Thank you for your enquiry.
We recreated this issue here and we had no trouble to take pictures in continuous mode. Can you please make sure you are using the latest Firmware and that the camera was reseted after the firmware update?
I hope that your question has been answered to your satisfaction.
Should you have further questions regarding this matter, please do not hesitate to contact us again.
When replying, please make sure this email is included.
With kind regards,
Tiago
This is my reply
Tiago,
My K3 has Firmware 1.01 and the problem still exists. I have just tried it and the problem definitely still exists. When I posted the problem on the Pentaxforums.com web-site other K3 users confirmed they had the same problem.
This is the camera settings
1. In Button Customization the AF button is set to Cancel AF
2. AF mode set to AF.C (continuous)
3. Drive mode set to continuous (high)
With my K5 and these settings when I am taking photos at a rugby match and a player is kicking a conversion kick I focus on the rugby ball then press the rear AF button to cancel autofocus then I re-compose the photo and take a burst of photos when the player kicks the ball.
With these settings set on my K3 it will only take a single photo not a high speed burst of photos. It is as if the cancel AF button also cancels the continuous drive mode.
It's not easy to explain in writing but I hope this helps.
Can someone with a K3 please see if their camera has the same problem.
Dear Mr. Miller,
With kind regards,
Tiago
This is my reply
Tiago,
Posted 05/02/2014 - 18:34
I've just updated to Firmware 1.02 and problem hasn't been fixed
Posted 05/02/2014 - 19:21
As a workaround, would you achieve what you want by using the back AF button exclusively to do the focusing?I've just updated to Firmware 1.02 and problem hasn't been fixed
That is, disable the 'AF on half-press'?
Then you could focus once (with the back AF button), then recompose and fire a burst with the shutter release.
I totally agree that it's not acceptable for Cancel AF to cancel all kinds of other things as well, but it might get you where you want to be until they fix it, if they can be bothered to actually address the issue (rather than send you a standard fob-off reply).
It would also be good to see if any other K-3 users here can confirm this behaviour.
Posted 05/02/2014 - 19:44
Yes Chris, there is a couple of ways around the problem, I suppose it's just me being fussy and not like being told there isn't a problem when there is As a workaround, would you achieve what you want by using the back AF button exclusively to do the focusing?
I've had the problem confirmed by a couple of K3 users on the other forum.
Posted 05/02/2014 - 19:57
It's not 'being fussy' at all, I totally agree that it's worth kicking up a fuss, even if there's a workaround.ChrisA wrote:
The default reaction of these so-called tech "support" departments is to assume that the person reporting a problem is an idiot (most probably are, to be fair, but that's no excuse), and to send a standard "go away" sort of reply.
If it's not fixed by the time I get a K-3 I'll be kicking up my own fuss too - the very least they should do is admit the problem and say when/if they'll be able to address it.
Posted 05/02/2014 - 20:02
I'm just waiting for them to get in touch to tell me to upgrade to Firmware 1.02 , I think this problem could be around for a while.
Posted 15/02/2014 - 17:37 - Helpful Comment
There's absolutely no bug and trouble with af off using rear af button when continous shooting and constant af ... Just put these setting to your camera :
- C3-16 : 2 or wathever you want ...
- C3-17 : 3 id ...
AND !
C4-25 : 1 - OFFFFF !!!
And it will work great
it seems logic ...
http://www.ricoh-imaging.fr/fr/Fred-BOEHLI.html
- C3-17 : 3 id ...
AND !
it seems logic ...
Posted 15/02/2014 - 18:26
No need to be agressive with customers support ...
Posted 15/02/2014 - 18:30
- C3-17 : 3 id ...
AND !
it seems logic ...
Cheers that works. I'll just have to remember I have catch-in-focus turned off now.There's absolutely no bug and trouble with af off using rear af button when continous shooting and constant af ... Just put these setting to your camera :
- C3-17 : 3 id ...
AND !
it seems logic ...
I still think there is a bug though, on my K5 I always have catch-in-focus on and it doesn't effect the Cancel AF button/continuous shooting. I think the settings should be consistent across the range of cameras.
There again, does that me I can now use the catch-in-focus with my DA 100mm macro, on my K5 the catch-in-focus doesn't work with AF lenses even if you had AF turned off.
Damn just checked it and no catch-in-focus doesn't work with AF lens on K3, same as K5 so I think it shouldn't effect the effect the Cancel AF button/continuous shooting either.
I'll say it again settings should be consistent across the range of cameras.
Posted 15/02/2014 - 18:41
Agressive ?????
Posted 16/02/2014 - 23:37
mille19 : i wasn't talking about you ))))
"I still think there is a bug though, on my K5 I always have catch-in-focus on and it doesn't effect the Cancel AF button/continuous shooting" -> I agree with you but same time not ))
Very happy you can so work ... with c4-25 Off : rear af off with c4-25 On : Trap focusing )))
Best regards from Paris
Posted 16/02/2014 - 23:40
"There again, does that me I can now use the catch-in-focus with my DA 100mm macro, on my K5 the catch-in-focus doesn't work with AF lenses even if you had AF turned off"
I agree, on k5 it works with lenses that have a AF Off button or manuel lenses ...
On k3 i didn't check with others ... but i will !
Posted 17/02/2014 - 12:38
I never realised about CIF either, I use it alot with an autofocus lens, it was only after reading this tried it with just the lens and it wouldn't work right, it was after 1/2 hour mucking about I realise I usually use extension tubes, strangely enough played the game again
20 years
On the K3 this doesn't happen it will take a single shot then you have to release the shutter button and then press again to take the shot, it's like setting the AF button to cancel AF also cancels the FPS shooting not just the AF.
It's not easy to put in writing but I hope I've made it clear.
